View Full Version : What is an LS3 from a 2015 Camaro worth
Roe
05-31-2015, 10:31 PM
Hi guys I have an opportunity to purchase a LS3 from a 2015 Camaro with about 2000 miles.
This is what it comes with:
(1/2) You get LS3 with all accessories on front and a/c unit ,wire harness ,ECU,Gas pedal,6 speed manual transmission bolted to the motor the one that came with
(2/https://www.pro-touring.com/webkit-fake-url://fe1eca56-b4db-4fdf-ba42-fbd356aba0b8/imagejpeg2) the motor clutch pressure plate ect.. it all there shifter also. All from a 2015 ss camaro with under 2000 miles
Thanks in advance
Schwartz Performance
06-01-2015, 04:25 AM
I'd say 7000-8500.
Retail would be a little over 10k for brand new stuff.
-Dale
andrewb70
06-01-2015, 06:14 AM
Keep in mind that the OEM TR6060 transmission is a lot harder to adapt for swaps than a new Magnum. The Camaro use an IRS so the flange yoke on the trans is fixed. This isn't a huge issue but it has to be dealt with somehow. Also the shifter is not exactly swap friendly.
icemanrd19
06-01-2015, 08:02 PM
$7000 to $7500
