Ishmael
05-26-2015, 01:59 PM
I didn't put this in restoration because I'm not certain my problem wasn't caused elsewhere. I don't have my steering wheel back on all the way because I'm having a problem with my turn signals. They won't stop no matter what position the switch is in. I didn't put the wheel all the way on because I don't want to take it back off. I have the body grounded to the frame, the engine to the frame and even the number to the rad support. The computer is grounded to the firewall. Here's where it gets tricky. If I have the convertible top switch installed it doesn't work but if I hold the housing in my hand it works. I also seem to have a bit of dust around the signal switch mechanism. My LS engine runs but the gen light on the dash stays on. PSI did the engine harness if that helps. Any ideas ?
thanks
Scott
thanks
Scott
