4MuscleMachines
05-23-2015, 06:20 PM
These shocks are for 71-73 Mustangs but will fit 69-1970 Mustang as well since I will provide the OEM shock caps for a 71-73 car that you can simply remove your 69-70 shock tower caps and install these without modification.
The rear set of two IAS shocks fit 66-73 Mustangs and the front will fit either 69-70 or 71-73 (with the provided shock caps). These shocks were put on my car and then removed since it went under a pro-touring upgrade that took way longer than anticipated. That's why they have less than 50 miles on them. The shocks do not leak nor have they ever been damaged or rebuilt. I am the original owner and can provide a reciept from Summit Racing as well.
The only issue is that I rattle can painted them satin black so they would look stock. They are originally red in color with black accordion boots.
You can still find these sought after shocks occassionally on eBay for at least $120 each. My price is $170 delivered to your door within the contiguous USA. Thanks!
