View Full Version : Where can I buy these Relay Terminals?
tonyvol
05-22-2015, 08:53 AM
Hey guys, I need the following terminals for some relays I'm wiring up. Does anyone know where I can get these connectors without buy 50 of them. Waytek has a minium order of 50.
http://www.waytekwire.com/item/32074/TERMINAL-FOR-RELAY-CONNECTOR/
Tony
cactuss4
05-22-2015, 10:23 AM
ebay is where I buy all my terminals
10-12 GAUGE 25 PK UNINSULATED QUICK DISCONNECT FEMALE .250 TERMINAL CONNECTOR
But why not get insulated ones instead?
http://www.ebay.com/itm/10-12-GAUGE-25-PACK-NYLON-FULLY-INSULATED-QUICK-DISCONNECT-FEMALE-250-TERMINAL-/271244505017?pt=LH_DefaultDomain_0&hash=item3f276eafb9
Or something like
http://www.ebay.com/itm/Female-Grey-Spade-Terminals-10-12-Gauge-FS10GP-10PCS-/321155216037?pt=LH_DefaultDomain_0&hash=item4ac657b2a5
Tory
Schwartz Performance
05-22-2015, 11:35 AM
^^^ Those aren't relay connectors. The ones he's looking for have a tab on them to snap into a plastic socket.
I don't know of anywhere that sells them individually.. since for .16 cents they don't make enough to have a person grab one of them, put in a bag, and ship out. lol.
-Dale
sjaroslo
05-22-2015, 11:46 AM
Terminal Supply Company (terminalsupplyco.com, catalog pages 148 & 149) is usually a good source, but i don't think that they carry it in your specification.... And I don't know what their minimum order would be, even if you could get the small quantity of connectors that you were looking for.
marolf101x
05-22-2015, 12:23 PM
Mouser.com
cactuss4
05-22-2015, 01:04 PM
-Dale
Ahh ooops, sorry about that!
McMaster/Mouser than
Tory
H2Ogbodies
05-22-2015, 04:37 PM
I stock them but shipping will hurt! I also stock mountable interlocking 70A relay bases too. PM if ya want.
dontlifttoshift
05-23-2015, 05:38 AM
Oohh, where did you find 70 amp interlocking relay bases. Will they interlock with the 40a ones?
H2Ogbodies
05-23-2015, 04:29 PM
I order them in bulk (300+ at a time) so that I can order the bases only and NOT the relays and terminals included. I try to only stock actual Delphi connectors and terminals where I can. And yes, they do interlock with the standard 5-pin relay bases also.
H2Ogbodies
The bases are Delphi direct....and can take up to 8 weeks to get so I order a lot at once.
renegade6
05-23-2015, 07:32 PM
American autowire should have smaller quantities. Napa also has a lot of specialty terminals, although they may not be on the display, they normally can get them.
all4sho
07-17-2015, 05:39 PM
any real car stereo shop/installer has them in stock
H2Ogbodies
07-17-2015, 07:47 PM
If you want/need a 70A interlocking relay base, they are $7 each. I use them primarily as a replacement power window control relay in my various 63-81 GM harnesses where customers want either auto down windows or both auto down/up. Its nice to integrate a base that can be mounted in the same location as the GM window relay (most are obsolete now) so I buy them in bulk.
