View Full Version : Hydraulic clutch conversion, slave does not retract
neongreen
05-20-2015, 08:40 AM
I'm converting a fox body t5 to hydraulic using a bracket and CNC brand slave cylinder.
https://static1.pt-content.com/images/pt/2015/05/IMG_20150420_214152-1.jpg
https://static1.pt-content.com/images/pt/2015/05/IMG_20150420_214614-1.jpg
I adjusted the rod so that it was snug to the fork and then depressed the clutch pedal, but the fork did not return to it's original spot. for the next 2-3 pedal depressions, the fork would move forward and not retract. after that, when depressing and releasing the pedal, the fork would move forward and retract. Why can I not get this fork (and TOB) to retract? I'm using a wilwood master cyl if that makes any difference. The TOB would slide smoothly on the input shaft sleeve prior to installation.
no go nova
05-20-2015, 07:32 PM
Only advice I can think of is try bleeding it some more. Did you reverse bleed the system?
72BBSwinger
05-20-2015, 08:20 PM
You might be overcentering the pressure plate fingers. The pressure plate should return the fork on its own. Try not to release the clutch TOO much if ya catch my drift.
