neongreen
05-20-2015, 08:40 AM
I'm converting a fox body t5 to hydraulic using a bracket and CNC brand slave cylinder.
https://static1.pt-content.com/images/pt/2015/05/IMG_20150420_214152-1.jpg
https://static1.pt-content.com/images/pt/2015/05/IMG_20150420_214614-1.jpg
I adjusted the rod so that it was snug to the fork and then depressed the clutch pedal, but the fork did not return to it's original spot. for the next 2-3 pedal depressions, the fork would move forward and not retract. after that, when depressing and releasing the pedal, the fork would move forward and retract. Why can I not get this fork (and TOB) to retract? I'm using a wilwood master cyl if that makes any difference. The TOB would slide smoothly on the input shaft sleeve prior to installation.
