View Full Version : 70-78 Camaro New Vintage custom Guage panel FS
1976CamaroGuy
05-19-2015, 05:43 AM
Thinking about changing my Gauge set up a little and seeing if anyone is interested in my current set-up?
I paid around $750 for the gauges not including the Covan Bezel and the modifying I did to that. The coven bezel runs around $160 new.
I'll need to get $520 shipped (lower 48) for me to feel comfortable selling this.
Guages: New Vintage 69 series Gauge set
http://www.newvintageusa.com/1969.html
It has the Electronic Speedo, Tach, Water temp, Oil Pressure, Volt, and Fuel
Here's the cluster and what you would be getting less the wiper switch or headlight switch. But if you want a used headlight switch with a new billet knob pull I'll throw that in.
I modified the Covan bezel by texturing it and painting it sem landau black.
For the turn signals, hi-beam, check engine, and brake warning lights I dissected the lens that game with the new vintage kit and placed them in cut-outs I made in the coven bezel.
The are black when off and will light up when needed. My goal was to make it look somewhat factory. The led's have been hot glued from behind and are nice and sturdy.
My car is in the body shop, but I will include the water temp and oil pressure senders if someone is interested in this cluster. I will have to go to the shop and get the senders off the motor.
The speedo is electronic so if your trying to add this to a cable driven tranny you will need to get a sender for that.
I'm not planning on including the harness I built to wire up the gauges, since the original set up didn't come with one. But we might can work something out for $45 extra for me to leave it on and I can cut the pigtail from the other end of the car. But again I will need to go to the body shop and do this.
As it stands, you'll get a pack of blue crimp connectors and you can wire this up per the instructions.
Hopefully I covered everything If you have any questions please ask
https://static1.pt-content.com/images/pt/2015/05/20140422174940_zps83efd090-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2014-04-22174940_zps83efd090.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/20140422174947_zps56be1ca5-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2014-04-22174947_zps56be1ca5.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/20140422174944_zps4312a079-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2014-04-22174944_zps4312a079.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/20140423192249_zpse8126f0a1_zps4xew50ol-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2014-04-23192249_zpse8126f0a1_zps4xew50ol.jpg.html)
Turn signals
https://static1.pt-content.com/images/pt/2015/05/20140424203546_zpsa466c24f1_zpsd5yut2t5-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2014-04-24203546_zpsa466c24f1_zpsd5yut2t5.jpg.html)
Center instrumentation
Note the brake is amber and the check engine is red, I have since swapped the colors so they are correct now
https://static1.pt-content.com/images/pt/2015/05/20140424203453_zps87f37f121_zpsh6jroopn-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2014-04-24203453_zps87f37f121_zpsh6jroopn.jpg.html)
I also added some labels for washer and headlight....switches are not included but I think I can round up a used headlight switch and a billet pull knob if you want it
https://static1.pt-content.com/images/pt/2015/05/2015020820122922_zpsj59melil-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2015-02-08%2012.29.22_zpsj59melil.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/2015020820122859_zps5qbbcgec-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2015-02-08%2012.28.59_zps5qbbcgec.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/2015010420165001_zpseevdgnsv-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2015-01-04%2016.50.01_zpseevdgnsv.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/2015010420165020_zpsmkwy7ldq-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2015-01-04%2016.50.20_zpsmkwy7ldq.jpg.html)
1976CamaroGuy
05-19-2015, 11:17 AM
Will work in other applications if you didn't use the Camaro bezel obviously. But I will not separate.
Speedo and tach are 3-3/8" if anyone wanted to know
1976CamaroGuy
05-19-2015, 02:18 PM
I'll go ahead and include the harness for the price, it's professional grade wire that came with my AAW kit, most are actually labeled as to where it goes. What I'll do is cut the pigtail back about 6" and you can splice it into your car...pretty much ready to go.
The tach wiring also has a capacitor wired in so that the tach gets a full signal if your using it with an LS engine.
https://static1.pt-content.com/images/pt/2015/05/2015051920171226_zpsrdhha9kz-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2015-05-19%2017.12.26_zpsrdhha9kz.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/2015051920171209_zpsp70jnyzs-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2015-05-19%2017.12.09_zpsp70jnyzs.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/2015051920171218_zpsujwxpf5l-1.jpg (http://s1310.photobucket.com/user/1971camaroguy/media/My%201971%20Camaro/New%20Vintage%20Guage%20cluster/2nd%20design/2015-05-19%2017.12.18_zpsujwxpf5l.jpg.html)
patobusta
05-19-2015, 06:32 PM
IŽll take it.
Will email you for details.
custom 68
05-20-2015, 07:46 AM
I will be on the list if something falls thru on this sale.
David
1976CamaroGuy
05-20-2015, 11:00 AM
ok, no problem - should be getting the payment on these Saturday per agreement with the 1st person that wanted them
1976CamaroGuy
05-23-2015, 09:58 AM
Keeping it alive
patobusta
05-23-2015, 12:23 PM
Payment sent.
Thanks dennis
1976CamaroGuy
05-23-2015, 12:24 PM
no problem, and thank you
SOLD
