View Full Version : FS/Trade 1972 Camaro RS Pro-Touring
72RS
05-17-2015, 10:26 AM
1972 Camaro
Many more pics and video available upon request.
Please feel free to contact me to discuss the car.
I purchased the car 4 years ago and did a top quality complete restoration. Car has less than 2400 miles since restoration. Everything from front to back and top to bottom was replaced. Car runs and drives wonderfully.
I was very fussy when putting everything together and spared no attention to detail. Car wins pretty much every show I enter in it and won first place at the Carlisle GM Nationals in 2014 for 70-81 Camaros.
Body is STRAIGHT and car has no rust. Car was painted spring of 2014 with PPG code 54 “Solid Red” stripes are buried in the clear. I put a new grille in after paint and the bumpers are rechromed original bumpers (not repops)
Engine-
383 Stroker done by Mark Small Racing Engines
Scat rotating assembly
Keith Black Pistons
Brodix IK 200 aluminum heads
Edelbrock Air Gap intake
AED 750 carb
MSD distributor, 6a box and Blaster 2 coil and wires.
Comp Cams Hyd Roller cam- Lift 540/562 Duration @.050 242/248 Lobe sep. 110
Isky roller lifters
Scorpion roller rockers 1.5/1.6
Hedman 65104 headers ( coated by Jet-Hot), Pypes 2 1/2 stainless exhaust with x-pipe and Magnaflow mufflers.
Tuff Stuff polished140 amp single wire alternator
Weiland polished water pump
Billet Specialties Alt and PS pump brackets
Billet Specialties Polished aluminum water pump and crank pulleys
Billet Specialties valve covers
Optima Redtop battery (purchased April 2015) with Billet Specialties tray and holdown
Ron Davis Racing radiator with dual fans and shroud
Fesler polished fender braces
Holley fuel pump with braided lines and AN fittings
ARP bolts throughout
Right Stuff fuel lines
Dyno sheet shows 497 HP and 491 TQ
DSE wiper motor
Billet aluminum overflow can
American Autowire Classic upgrade wiring harness
Transmission-
Monster built 700r4 with B&M lockout controller
Monster 2600-2800 stall
B&M external cooler with braided lines running from transmission.
Rear-
10 bolt posi rear with new Richmond 3.42 gear. Moser Axles and differential cover
Suspension/steering
Hotchkis 1 ½ lowering leafs in the rear
Hotchkis 2” drop coils in the front
Bilstien shocks on all 4 corners
Ridetech tubular upper control arms
Del-A-Lum bushings installed in stock lower control arms
AGR 12:1 steering box with braided lines and AN fitting running to new saginaw pump
Moog Tie rods and ball joints.
Steering column was purchased from Steering Columns Galore last year and has a Billet Specialties hub and steering wheel with half wrap.
Custom Works Sub Frame Connectors
Brakes-
Hydratech Hydroboost brake system with all braided lines.
Wilwood 4 wheel disc setup
Wilwood proportioning valve
Interior (everything listed, other than the console, installed new in 2013)
ACC carpet
OER dash
Auto Meter gauges
Leather seats
Original GM center console with horseshoe shifter
Headliner
Package tray
Sill plates
Pioneer AM/FM CD player with Memphis 6x9 in rear and 2- 4” speakers in front
New glass and weather strip all the way around
Billet Specialties pedal covers
HaloGaurd fire extinguisher
Billet Specialties door locks and window cranks.
Car also has a custom trunk enclosure and carbon fiber upper door panels and shifter bezel
Wheels and tires- Purchased March 2015 have less than 200 miles on them
Nitto 555’s
275/40/18 on rear
235/40/18 on front
Boss 338 18.8 front &18 x9.5 rear
72RS
08-09-2015, 03:24 AM
New price...
I have also installed a set of Eddie Motorsports polished Billet hood hinges. Just have not got a pic yet.
Gemelli
08-09-2015, 04:26 PM
PM sent
72RS
08-10-2015, 04:59 AM
PM sent
sent you a response...thanks.
Pat
Box Nova
08-12-2015, 05:12 AM
What kind of trades are you interested in?
72RS
08-12-2015, 07:23 AM
Would be interested in a 2006-07 or up Saleen Extreme.
72RS
08-19-2015, 01:38 PM
Ttt
ssx
08-20-2015, 02:59 PM
heck of a nice car...Best of luck!
72RS
08-20-2015, 03:30 PM
Thank you!
jgdds
08-25-2015, 03:43 PM
Sent you a PM.
72RS
08-28-2015, 09:08 AM
car is sold.
