View Full Version : Custom Build Shop
D-$
05-14-2015, 07:18 AM
I am a rookie so please be gentle. When it comes to having a shop build a PT 69 camaro with LS engine. What should one expect to pay? Are there any shops on the west coast folks have had good experiences with? Currently I don't have a car so cost of that would need to be included.
69 camaro straight body - 10-15k
Paint & body work - ?
Engine & Drive Train t56 6speed
New subframe
Suspension
brakes
tires & wheels
mini tubbed
smooth firewall
A/C
rlodad
05-14-2015, 08:21 AM
69 camaro straight body - 10-15k True- no suspension, wiring, fuel system, wheels/tires, etc.
Paint & body work - ? 8-30k depending on how much you want. 2k if you do it yourself (I did).
Engine & Drive Train t56 6speed zz4- 6-7k, ZZ383 8-10k, LS or LSX 12-30k TKO600- $2500 T56 $3-4000
New subframe DSE 7k, standard front with DSE speed kit 3- 4.5k
Suspension Rear 4 link- 2.5k, IRS 7-12k
brakes Big discs? 4k, smaller 2-3k
tires & wheels 3k-10+k
mini tubbed Tubs $350 What a deal!
smooth firewall Welding- $400 Bodywork and paint- $500-$1000
A/C Vintage air $1500 +/_
This is like asking what a house will cost. VERY difficult, but the one thing I know from experience is that it will be 1.5-2x your highest prediction. I guessed at the above costs, but remember- you will change your mind and redo things and you will have MANY small costs that will add up. IMHO, there is no question it is MUCH cheaper to buy a "done" car than to have one built, even if you have to change things. If there is any question whether you can afford what you want to do, don't do it. There are as many unfinished projects as finished ones. Labor can easily be nearly as much as the parts if done right. A car like the nicest ones here is nearly impossible to have done by professionals for under six figures. I did mine myself and it cost nearly that.Here's a link to a limited version of my build: https://www.pro-touring.com/threads/90846-My-1st-PT-69-Camaro-vert-build?highlight=notata
dhutton
05-14-2015, 09:18 AM
I think the guy for you to talk to would be Vince at Meanstreets Performance:
http://mspfabrication.com/
He is on this forum. User name MrQuick. He has several levels of build including what he calls his Blue Collar builds for regular folks with limited budgets.
Don
srh3trinity
05-14-2015, 11:55 AM
My build is similar to what you want. Shop built, aftermarket subframe and rear suspension, wheels, pain and body and so on. I would say a rough guess would be 40-50k on the low side and the sky is the limit on the high side. Good paint and body can be 10k on the low side. You can easily have 25k or more in parts in a PT style build and again that is on the low side. Things like wiring harnesses, cooling and fuel systems, new rear ends, brakes all start to add up pretty quickly.
srh3trinity
05-14-2015, 11:58 AM
I re-read the rlodad post and his rough numbers are pretty spot on. It all adds up. I had to define my parts budget. As far as the labor, the more I want to do with body mods, the more it will cost.
D-$
05-14-2015, 12:58 PM
very good feedback. This site is so informative and everyone is very helpful. I think at the end of the day I want to build from the ground up and worry less about the esthetics and more about the function. Engine, sub-frame, etc... over interior and paint. I can always spend more money as time goes judging by what I read on here.
chpr1972
07-03-2015, 08:42 PM
Buy a car and slowly change it. I have a 66 Lemans conv that I bought without a motor and trans. It now has a BBC 496 10:1 stroker crank 230 236 515 lift comp roller cam. Every thing in the motor is new. It has a center force flywheel and trick flow balancer. A lakewood bellhousing and a TKO600 5 speed trans with a hydraulic clutch and heavy duty crossmember. Rear end is a Ford 9" posi with aftermarket axles.Front and rear suspension was rebuilt and has Heidt 2" dropped spindles and adjustable upper control arms and Hotchkis lowering springs. Wilwood 12.88 rotors and 6 pistons front and 4 piston rear brakes with a Wilwood master cylinder. Hooker comp headers 2 1/8" with a complete pypes exhaust system and rear chrome outlets. The AAW wiring harness and a Vintage Air conditioning and a 'front runner system mounting 100 amp alt and detroit power streering unit. Dual fans on an alumiumn radiator. Fuel system includes a tank inc gas tank, fuel pump and a holly HP EFI mounted on a old school tunnel ram with 2 4BBL throtle bodies and a gasser style air filters. Ansen sprint wheels 17" wheels and performance tires. A Dakota Digital dash and a Custom sounds radio and small amp and a 4 speakers. The car still has a stock interior and body. In the last 3 years some rust has popped out on the doors. It still has not been painted. The top also has to be replaced but I have replaced the motor , cylinders and hoses. Bumpers need rerchromed and a lot more to do. There is almost no labor on the car as I did it all except the motor. Small stuff kills you. Nuts and bolts, window regulator rollers, dynamat,misc adds up FAST! You will not believe what some of the little parts cost. Window rollere $6.95 each x 3 or more per window. I have some where just under $50,000 invested in parts and original purchase. I am retired and this keeps me alive. BUT I WISH I WOULD HAVE BOUGHT A FINISHED CAR AND SLOWLY CHANGED IT HERE AND THERE AND ENJOYED IT FOR LAST 2 1/2 to 3 YEARS. Just about every thing done to the car has had to be redone at least twice as some thing added means you have to re do something to make it work. JUST SAYIN.
snappytravis
07-03-2015, 09:23 PM
Don
Vince is a good guy, I have dealt with him a few times and he is also great for giving advice. He is crafty when it comes to saving a person a few bucks. I have noticed on some of his builds. My concern would be more so of who not to take it to... Search around the forums and get a budget. Good luck
Bryan O
07-21-2015, 06:16 AM
New subframe
Suspension
brakes
tires & wheels
mini tubbed
smooth firewall
A/C
$200,000-250,000 to do it right. A little less if you don't add the bling. Things like billet hood hinges, billet running lights, billet....
I highly recommend Best of Show Coachworks in Escondido. Talk to D!ck. He's the owner. They've built many top 69 Camaro PT cars on the road. Including mine, Bad Penny, One Lap, Matt A's and Greg's 69's...
Good luck. Have fun!
parsonsj
07-21-2015, 06:55 AM
$200,000-250,000 to do it right. A little less if you don't add the bling. Things like billet hood hinges, billet running lights, billet....That's a realistic number for a push-button car with new drivetrain, suspension, brakes, wheels, interior, and paint.
$50K ground-up builds with professional labor do not exist.
dhutton
07-21-2015, 09:00 AM
Damn, I guess I will keep hacking away in my backyard shop. :jawdrop: I thought $75-100k could get you a nice car.
Don
parsonsj
07-21-2015, 10:20 AM
Let's do some math. :)
Let's assume a labor rate of $75/hour. Let's be optimistic and put the build at 600 hours. (200 hours for paint, 100 for interior, 300 for build itself). Rack up the parts: front sub-frame: $7500. Rear suspension $6000. Brakes: $4500. Wheels: $5000. Tires $1500. Seats: $4000. Engine/harness/front drive: $12000. Transmission: $3000. Paint materials: $2000. Plumbing hose, ends, adapters: $3000. Fuel tank: $3000. Car itself: $15000. BCM/Stereo/Gauges: $7500. A/C: $2000. Stuff I forgot: $10000.
Round number is $100k in parts. 600 * 75 = 45k in labor. That's $150K already, assuming a solid body to start, ordinary prices, and that I didn't forget anything. Put in some custom paint or bodywork or carbon fiber, step up to an LSA or LS9 engine, wrap the interior in leather, do power windows, locks and trunk, go nuts with the stereo, etc.
Anyway, $200K is pretty easy to do for a top-end car with all new brand-name parts. That's been my experience over more than a few builds.
dhutton
07-21-2015, 10:58 AM
I guess we better keep this thread away from our wives or our hobby (not to mention a few other things) might get cut short... :naughty:
Don
parsonsj
07-21-2015, 11:22 AM
I guess we better keep this thread away from our wives or our hobby (not to mention a few other things) might get cut short... What thread?
Ant
08-02-2015, 07:30 AM
Just thought I'd mention I saw a complete takeout CTSV motor and trans on the CTSV owners forum for 15k
vintageracer
08-06-2015, 07:54 AM
Cost (the money you spend building the car) will be the LEAST of your worries as it appears you "may" understand the cost of building the 69 Camaro you desire.
The BIG ISSUE you will face will be the people YOU hire who DO NOT do what they say they will do when they say they will do it! That alone adds cost to your build!
Expect 2+ years of MISERY with a poor choice!!!
How do you avoid all that MISERY AND EXPENSE?
Carefully choose the shop to build your car based upon the RECENT experiences others have had with that particular shop. DO NOT choose the shop you will use based strictly on price. You WILL get what you pay for! In most cases be prepared to transport a long distance as the better shops are rarely local.
The top notch shops are just that for a reason. Quality of work? Yes! Fabrication abililty? Yes! All the other hand holding that goes with building a car? Yes! Most importantly they complete their work in timely manner AS AGREED and yes these folks charge accordingly for their services!
The biggest mistake YOU can make building your Camaro COULD the first decision YOU make when YOU choose the shop to do the build on your Camaro. Search this site alone for all the war stories then search this site for all the success stories. The same shops continue to rise to the top of all the success stories. The same can be said for the parts you purchase for the build.
Choose wisely my friend!
D-$
08-06-2015, 09:57 AM
I have never been more encouraged and discouraged at the same time :) :( Thank you for the feedback.
dhutton
08-06-2015, 10:28 AM
Get with Vince, he will set you up within your budget.
Don
cactuss4
08-06-2015, 10:37 AM
Don
Site no longer loads and our conversation seemed to have been cut short (no followup after a few emails) So not sure what is going on there.
Tory
vintageracer
08-06-2015, 11:00 AM
Here is a post by the car owner TODAY from another thread on this site about the Lack Of Progress on his car build.
QUOTE:
"I have had a bit of a delay in my build. The guy that was doing the metal work on my car left the company and moved to another place down the road. :( They have been working on the hood this past month repairing areas around the hinge mount and attaching a hood scoop. The rear fender arches have been tack welded but still need completed.
I was talking with the shop owner yesterday and it looks like there is another year of work to do on the car. Just about every panel is having pretty significant modifications done to it and that takes time. I am a little frustrated since there hasn't been too much done in the past year. I can see this extending another 2 years. I need to evaluate options to make this project progress a little faster. I think I will take the car home and do some of the work myself."
ENQUOTE
HERE is a real world example POSTED TODAY of why the choice of the shop YOU choose to do the work is so IMPORTANT!
dhutton
08-06-2015, 11:38 AM
Tory
http://www.meanstreetsperformance.com/
Don
68EFIvert
08-06-2015, 11:41 AM
Vintageracer that was my post. LOL I just got back from meeting with another shop where the metal guy went to. My car will be moving there in September. They don't do insurance work and are finishing up with some long term projects in the next couple weeks. That will give me some time to do some adjustments to the suspension on my build.
Building a car can be frustrating. It WILL be over budget. It WILL take longer than you think it will. I learned long ago that things in life are rarely on my timeline and as soon as I realized that life got much more tolerable. That does not mean you have to stick to someone elses timeline though. Hence the move of my car. I now have to work with a different person's timeline/schedule. LOL!
Decline
08-06-2015, 12:03 PM
First..Take your budget and double it..HAHA
Then hope the "professionals" dont muck it up. Almost every person Ive taken my car to has eff'd up something (except Johnsons alignment, those guys are top notch)
The taste was soo very sour, that I bought a bunch of tools and I started doing my own work. My recent bent valve fiasco took 3 months for me to fix but it only cost me $200 in parts
I'd have had it done sooner if I didnt procrastinate so much
Point being Its way cheaper to buy a built car and change it then to build one from he ground up. Also theres no down time as you get to enjoy it immediatly.
i met a guy at a Camaro meet last year who bought a full DSE/Baer/forgeline car off a older gentleman who lost interest for $40k. It was built at Best in Show and prbly cost $100K to build. Yeah it was orange with black wheels and had a 502 instead of an LS but it was an amazing deal and great place to start off from.
