View Full Version : Getting rid of Corvette logo on C5 Z06 calipers
Paraman1
05-04-2015, 05:03 PM
Has anyone milled off or ground off the Corvette logo on a set of C5 Z06 brake calipers ? Since my calipers haven't sold I am starting to think I should just clean them up , sand them down and Cerakote them graphite black to match my trim and give it a bit cleaner look .
raustinss
05-04-2015, 06:01 PM
Why you asking us....you know you want to do it...give er hell. Oh and post pictures lol good luck
WallaceMFG
05-04-2015, 06:59 PM
I "modified" my C6 calipers to say "Chevelle" and it turned out really cool. But to answer your question it's aluminum so it mills off really easy, up to you if you want to do it or not.
protour_chevelle
05-05-2015, 04:28 AM
put a 60 grit flap wheel on your 5" grinder, grind it off, then follow up with some hand sanding with 120/220 and paint er.
pist0lpete
05-05-2015, 11:33 AM
I feel like I read somewhere that one of the newer GTO years has functionally the same calipers without the corvette script. I am not positive on the details but might be worth more research.
Apogee
05-07-2015, 07:15 AM
The 2005/6 GTO applications shared the front caliper design with the C6 Corvettes, but had "GTO" stenciled lettering on the face instead of the raised "CORVETTE" lettering. In that sense, pistOlpete is correct that you would have less work involved to do what you're proposing.
Tobin
KORE3
Buryingthesun
05-17-2015, 04:44 PM
if you grind it off yourself don't breath in the dust, it will probably kill you. . . eventually lol
Paraman1
05-17-2015, 05:29 PM
I work in construction , I almost guarantee I am breathing something that will kill me . Hell , you breathe air long enough it will kill you .
I generally wear a dust mask when sanding and grinding though :) My plan if the calipers aren't sold by tonight is to mill the logo off , sand the area smooth and then sandblast them clean before coating them .
Buryingthesun
05-19-2015, 01:05 PM
I smoke, I'm going to die one way or another. . . aluminum just gives you dementia and alzheimer's
