View Full Version : Adjusting Camber..
pitts64
05-03-2015, 10:09 AM
If I add negative camber by adding a shim to the rear bolt of one of my front upper control arms, will I decrease camber on the other side? My car has the same upper control arms as in the photo.. This seems to be the case with my car..
Thank you...
Rod
05-03-2015, 01:03 PM
if you shim only the back bolt you are adding camber and castor (mainly castor), if you shim front and back the same you are adding camber only
