View Full Version : 315 or 335's for mini tubed camaro?
Erik Beckett
05-01-2015, 07:23 PM
What size tire should I go with for a minitubbed 68 camaro? Rims will be 18x11 or 18x12's just not sure yet what package to do.
thanks Erik
parsonsj
05-01-2015, 07:29 PM
What size tires are on the front?
Erik Beckett
05-01-2015, 08:03 PM
I was planning on running an 18x8 with a 245 but after a lot of reading on here, BuddyP is running 18x9 with a 265 on essentially a stock front end. I have until Monday to adjust my order as needed.
Thanks, Erik
Erik Beckett
05-01-2015, 08:04 PM
I will have ridetech front and rear
dragonfly jones
05-01-2015, 08:36 PM
Have your same set up. im running 9x18 265 12x18 335
parsonsj
05-01-2015, 09:46 PM
I'd recommend you go with a 315 if you only have a 265 up front. You're going to struggle with understeer if you put the 335s on the back with such a small front tire.
You really need a 295 up front to make a 335 work in the back.
