View Full Version : Ridetech release - New 5th Gen Camaro suspension parts
Josh@Ridetech
04-30-2015, 04:31 AM
https://static1.pt-content.com/images/pt/2015/04/1_zps4i1khsii-1.jpg (http://s1356.photobucket.com/user/Ridetech2/media/1_zps4i1khsii.jpg.html)
Billet Rear Strong Arms 2010-2015 Camaro
With the continued success of our Camaro CoilOver and Air Suspension systems, we are now proud to release our new Billet Rear Strong Arms. The adjustable billet arms are the perfect compliment to your existing RideTech suspension.
•All designed, manufactured, assembled, and packaged in the USA
•All parts CNC machined out of US-made 6061-T6511 billet aluminum
•Trailing and Lower Control Arms feature mechanically locked alignment settings - no slipping under high loads with sticky tires
•Tab alignment system allows predictable, repeatable alignment changes in minimal time
•Lower Control Arm allows a nearly 4 degree range of Camber Adjustment
•Adjustable Trailing Arm allows proper suspension geometry to be maintained at extreme camber settings
•Trailing Arm, Toe Link, and Lower Control Arm are more rigid in compression, tension, and torsion than OEM parts, while saving 1.5lb in overall weight
•Toe links utilize Kevlar lined rod ends and lightweight aluminum adjusting sleeves
•Lower Control Arm includes integrated mounts for both FE3 (inboard) and FE4 (outboard) mounting style sway bars
•Trailing Arm and Lower Control Arm feature injection molded Delrin inboard bushings, greatly reducing suspension compliance under lateral and longitudinal loads
•Anodized Black with Laser etched RideTech logos
https://static1.pt-content.com/images/pt/2015/04/2_zpsrdlh3azk-1.jpg (http://s1356.photobucket.com/user/Ridetech2/media/2_zpsrdlh3azk.jpg.html)
https://static1.pt-content.com/images/pt/2015/04/3_zpsd3sw4glx-1.jpg (http://s1356.photobucket.com/user/Ridetech2/media/3_zpsd3sw4glx.jpg.html)
(#11505899)
__________________________________________________ _________________
Rear Splined Muscle Bar 2010-2015 Camaro
https://static1.pt-content.com/images/pt/2015/04/4_zpsmskuuwn3-1.jpg (http://s1356.photobucket.com/user/Ridetech2/media/4_zpsmskuuwn3.jpg.html)
Let's face it... the most overlooked suspension component is also one of the most important. The magic you could be missing in your suspension may be nothing more than simply adding or upgrading your sway bar(s)!
The 5th Gen Camaro MUSCLEbar™ was developed specifically for FE4 Camaro rear suspension and will greatly enhance the cornering performance of your car. We utilize the same splined bar design as most racing racing series use today. Available for stock FE4 lower control arms or RideTech Strong Arms
This kit also includes Posi-Link end links.
•Improves range of motion & eliminates binding
•Strong design prevents deformation and failure
•Positive transfer of motion through swaybar
•OEM high performance quality
(#11509103/11509102)
Rear Cradle Bushing Kit 2010-2015 Camaro
https://static1.pt-content.com/images/pt/2015/04/5_zpsouokfbva-1.jpg (http://s1356.photobucket.com/user/Ridetech2/media/5_zpsouokfbva.jpg.html)
Even in stock powertrain form, the 5th Gen Camaro's stock rear cradle bushings are problematic to say the least. The wheel hop and rear drivetrain oscillations that create the dog walking feeling under acceleration and deceleration are not only unsafe they just make the cars handling un-predictable. The good news is we now have a solution with our performance Rear Cradle Bushing Kit. In just a few hours and under $500 you can make the single most noticeable improvements to your Camaro's handling.
(#11509599)
Rear Cradle bushing Install Tool
https://static1.pt-content.com/images/pt/2015/04/6_zpsokw2omui-1.jpg (http://s1356.photobucket.com/user/Ridetech2/media/6_zpsokw2omui.jpg.html)
Installing your Camaro Cradle Bushing Kit is a piece of cake when using our Bushing Installation Tool.
(#85000005)
ChevelleNV
05-01-2015, 06:29 AM
how much are the control arms and sway bar? might have to pick these up for my Chevelle since it has a 5th Gen IRS in the back and has Ridetech control arms in the front..
Josh@Ridetech
05-06-2015, 09:39 AM
For all of the control arms, it's $2000. The sway bar is $800.
