View Full Version : Chevelle parts, X factor crossmember& BBC parts
gearhead 69
04-25-2015, 05:43 PM
New parts in boxes
Ati internally balanced balancer with arp crank bolt $275
350/400 turbo converter part# 60432 3800-4100 stall converter with anti balloon plates $300
Proform sbc/BBC mini torque starter $130
$175 proform electric blue water pump
$300 painless 8 circuit race car/prostreet harness
$40 for 2 red battery box kits
$40 trans cooler
$100 k&n tall velocity stack with air filter (fits dominator carbs)
$200 aluminum jegs double pass radiator 31w-19h
$30 universal radiator mounts
$200 stock 9' housing
$290 (2)Goodyear front runners 28.0x4.5-15
$75 cage mount switch panel jegs
X factor trans crossmember for 68-72 chevelle may fit other vehicles $350
2' drop bmr front and rear springs for 68-72 a body they've been put on for mockup and got a scratch on them $150
Front and rear qa1 billet aluminum single adjustable shocks new just been installed for mockup one rear one has a scratch $450 cost $600 new
Power master snug mount chrome alternator with bracket bnib $300 cost $360 new
Hardwood 70-71 chevelle 2' pin on hood in box $275 cost $400 new
Edelbrock rear upper adjustable trailing arms $150
Jegster rear non adjustable rear lower trailing arms $150
used parts
Stock front uppercontrol arms,lower control arms,stock spindles,rotors,and all brake parts off my 69 chevelle $350
1150 dominator carb that's been rebuilt and hasn't had fuel in it since,with new regulator and spacers $600
2009 gmc Denali 2wheel drive 6.2/6l80 engine wiring harness $250
2009 5.3 iron block ,has had all machine work done and has durabond coated cam bearings installed,stock bore $400
new floating gm 5.3 Pistons with vr,and has new rings $300
floating 5.3/6.0 rods has been checked at machine shop and cleaned $175
prolly forgetting some stuff lie add as I go,and Ile try to get pics up but for faster response text or call me, 318 439 1712,Terril
dropped72ss
04-25-2015, 10:00 PM
What's the red battery box kit?
gearhead 69
04-26-2015, 05:11 AM
555-10271 is the part number there for when u relocate the batteries to the trunk
gearhead 69
04-30-2015, 06:42 PM
Added few parts
gearhead 69
05-07-2015, 04:51 PM
Ttt.....
gearhead 69
05-21-2015, 05:01 AM
morning bump
Yelcamino
05-22-2015, 04:44 AM
What's the part number on the balancer?
gearhead 69
05-27-2015, 06:54 PM
Sile check it tomorow and pm u,sorry for the late response been super busy at work the past few days
gearhead 69
05-31-2015, 04:58 PM
ATI917060 7' balancer
Yelcamino
06-01-2015, 03:36 AM
Thanks for the part number.
ddavis15
06-03-2015, 05:36 AM
Interested in that X-factor if you still got it
gearhead 69
06-03-2015, 08:45 AM
yes its still for sale
spitfire980
06-16-2015, 04:02 AM
PM'd about the 2' drop bmr springs
spitfire980
06-18-2015, 10:46 PM
Did you get my PM?
gearhead 69
07-05-2015, 05:44 PM
Pm's replied
