68Malibu383
04-25-2015, 06:13 AM
Hey guys,
I have a '68 Chevelle with the Kore3 C5 front brakes and factory drums in the rear (plan to install the Kore3 C5 rear discs when time/money permit). I currently have the factory 10.75" booster and a 1.125 bore master cylinder. Engine generates about 11" of vacuum at idle. Have poor performance now, especially in parking lots - hard pedal at low speed and low brake function. Tobin recommended a 15/16 bore MC and I think I'll get the '77 Malibu unit.
Regarding the pedal ratio, I am using the factory lower hole on the pedal and the ratio is approximately 3.3. If I could move the clevis to the upper hole (factory used for manual brakes), the ratio would be closer to 6. However, the rod hits the top of the booster where it extends into the firewall before the clevis lines up with the upper brake pedal hole. I could drill a hole just slightly lower in the pedal arm but am concerned about the angle of the rod - will not even be close to center at the back of the booster hole where it comes through the firewall. I'm concerned about running the rod at an angle that is so far off from factory/being centered in the hole at the back of the booster assembly.
Should I be concerned about that angle and what have others done to safely get a better pedal ratio?
