Rass1958
04-23-2015, 06:25 PM
Have 6x heads and manifold will heads fix on 326 motor
68Formula
04-23-2015, 06:33 PM
Fit? Yes. But your compression would be would be less than 7:1. And the valves will hit the bore.
Rass1958
04-23-2015, 07:05 PM
What would be good heads to use
68Formula
04-24-2015, 03:39 AM
This will give you an idea of how many CCs you need.
http://www.wallaceracing.com/cratio0001.htm
The open chamber heads are much better, but the good compression ones, came on the 350 H.O. version (18s), so those would be hard to find. I'm not sure if the 1.96/1.66 valves would clear the tiny bore (The 326 had a 3.72 vs. the 350s 3.875). But, if you do find they clear, those would be the way to go.
http://wallaceracing.com/head1.htm
You could also consider the lower non-H.O. versions (17s, 14s, 47s) but you'd need to mill them quite a bit to get them in range.
http://wallaceracing.com/headmill.htm
