View Full Version : FS: NEW SBC Oil Pan, Gear Drive Timing Set, COMP CAM Kit with Lifters
vdubn
04-21-2015, 09:27 PM
I have the following items for sale that were left over from an engine build. All items are brand new, see details for each of the items below:
Brand new steel oil pan - $35 - Zinc coated. It was clearanced for a 400 crank.
Brand new Straight Cut Timing Gear set, comes with all of the pieces, including the cam button - $40 (cam button clearanced for timing cover)
Brand new COMP Cams Hydraulic flat tappet Camshaft Kit with Lifters. This was in the small block that I bought brand new unstarted, but the cam was too big for my needs. This cam is a big cam that the guy was going to use in his mud truck, but has a nice wide power range (2800 to 6800). Could also be used as a race cam or aggressive street cam. I posted pics of the cam spec sheet, but putting them in the description below as well. This whole setup (cam and lifters) cost about $230 from Comp Cams. Price is $140 for the cam and lifters.... all BRAND NEW
Here are the specs:
Part # 12-000-5
SN#: 0 2476-08
Grind#: CS 5090/5109 H8
Intake Gross Valve Lift: .584
Exhaust Gross Valve Lift: .579
Intake Duration at .006 Tappet Lift: 292
Exhaust Duration at .006 Tappet Lift: 302
Intake Duration at .050 Tappet Lift: 248
Exhaust Duration at .050 Tappet Lift: 253
Lobe Separation: 108 degrees
RPM Range 2800/6800
Stall Converter 2600
Same as Comp Cams 12-368-4 that Summit sells here for $133:
http://www.summitracing.com/parts/cca-12-368-4?seid=srese1&gclid=CK_U4tXI8sQCFYyTfgodBWcAmw
https://www.pro-touring.com/attachment.php?attachmentid=111858&stc=1
https://www.pro-touring.com/attachment.php?attachmentid=111859&stc=1
https://www.pro-touring.com/attachment.php?attachmentid=111860&stc=1
https://www.pro-touring.com/attachment.php?attachmentid=111861&stc=1
https://www.pro-touring.com/attachment.php?attachmentid=111862&stc=1
vdubn
04-24-2015, 08:11 PM
Sold
