View Full Version : cts-v brembo 4 piston brake swap
Rboisvert86
04-18-2015, 03:43 PM
I need swap info for the cts-v 4 piston caliper I've seen post on ls1.com post http://www.ls1.com/forums/f66/cts-v-install-w-pics-115446/ the calipers both bolt up on the same according to the post using the z06 rotor I would use the brake brackets from kore3 for the z06 6 piston and the z06 rotor as the above post used on the 4th gen camaro but in the rear can I get a 4th gen camaro drum in hat parking brake assembly and bolt the rear caliper to that or would a z06 parking brake assembly from flynbye.com be better I think there $385 kore3 also makes some kind of setup but they sell a rear caliper mount for like 140$ or a parking brake set up package when you select no caliper pad or rotor and just get the drum in hat setup it's like $750 I want to achieve a cts-v front and rear caliper with a z06 rotor and still have a e brake setup to stop if I have a line failure and suggestions anyone do a similar mod with oem parts the rear end on my car is a gm 10 bolt
CamaroMike
04-24-2015, 08:18 AM
I was just researching the same thing! Would also like to know.
GatorSS1963
10-09-2015, 09:10 AM
As long as you have the right spindles, your OK. Call the guy at kore3.
Barrrf
10-09-2015, 09:37 AM
First, use some periods. I cant read that without my brain hurting.
Second, what car?
1967camarors
07-27-2020, 01:45 PM
HI: You may want to check out https://bigbrakeupgrade.com/. They offer complete kits or components for this conversion. I did this same swap (CTSV Brembo 6 PISTON FRT 4 PISTON REAR) on 1967 cAMARO. Keep in mind you will need custom wheels with over 1.77" caliper clearance.
jps68
01-02-2021, 08:14 AM
Hey 1967 Camaro - you have any pics of the brackets and install?
