View Full Version : 1966 Mustang Coupe Restomod
rusty428cj
04-15-2015, 02:05 PM
This is what we are starting with. There is not a lot of rust but since Ford did not prime a lot of the inner structure we will be removing all the sheetmetal do any needed rust repair and epoxy priming. The plans are to install Rod & Custom front and rear suspension, Wilwood brakes, Currie 9", AOD and a 347. The body mods will be fender flares, drip rails removed, cowl vents filled in and maybe a few other things as we go.
https://static1.pt-content.com/images/pt/2015/04/DSCN0651_zpsyrrctx59-1.jpg
One of the first things we did after bracing the body was to remove the cowl
https://static1.pt-content.com/images/pt/2015/04/DSCN0668_zps5qfpl1ed-1.jpg
The quarter panels were removed
https://static1.pt-content.com/images/pt/2015/04/DSCN0678_zpsfmirr3go-1.jpg
The roof was also removed and there was only surface rust but in a few years it will get worse if it is not cleaned up now
https://static1.pt-content.com/images/pt/2015/04/DSCN0692_zpsb3jcn1vv-1.jpg
dontlifttoshift
04-15-2015, 05:11 PM
If the unprimed inner structure made it 50 years, what will happen in the next few? Was the roof rotted so you were removing it anyways? Serious questions.
xsboost90
04-15-2015, 06:01 PM
wow looks like my car- guess i need to post my project
rusty428cj
04-15-2015, 06:15 PM
We did not see any rust but we did find rust as you will see once we start the repair.
rusty428cj
04-16-2015, 05:23 AM
I'm sure a lot of you are wondering why do we remove all the sheetmetal. The quarters were replaced at one time and we did not trust the workmanship and once they were removed we found rust in the outer wheelhouse. The roof was removed because Mustangs are known to rust in the inner structure in the front by the top of the A pillar. In this case we were lucky and only had surface rust but over time would became holes. The other area on coupes is the sail panel inner structure and we did find rust. A little rust on the left side but the right side had a few small rust holes starting.
https://static1.pt-content.com/images/pt/2015/04/DSCN0714_zps8flekmil-1.jpg
rusty428cj
04-17-2015, 02:03 PM
New firewall and cowl was sanded and epoxy primed
https://static1.pt-content.com/images/pt/2015/04/DSCN0601_zpsnvtkufya-1.jpg
https://static1.pt-content.com/images/pt/2015/04/DSCN0602_zps4nhse7zj-1.jpg
The cowl side panels and A pillars needed to be replaced
https://static1.pt-content.com/images/pt/2015/04/DSCN0727_zpsulmzjctf-1.jpg
Test fitting
https://static1.pt-content.com/images/pt/2015/04/DSCN0744_zpsppnm5etu-1.jpg
Crestronwizard
04-18-2015, 08:54 AM
Hey Rusty! Good to see another Coupe project :). How have you been?
rusty428cj
04-19-2015, 07:07 AM
We have been very busy and it is hard to find time to work on my projects.
rusty428cj
05-03-2015, 07:43 AM
Ready for epoxy primer
https://static1.pt-content.com/images/pt/2015/05/DSCN0837_zpseadfzera-1.jpg
https://static1.pt-content.com/images/pt/2015/05/DSCN0838_zpskt8tkmvk-1.jpg
Two coats of SPI black epoxy primer
https://static1.pt-content.com/images/pt/2015/05/DSCN0839_zpsfdi6qxga-1.jpg
https://static1.pt-content.com/images/pt/2015/05/DSCN0843_zpscneb4jk8-1.jpg
rusty428cj
05-03-2015, 07:57 AM
Lower cowl welded in place
https://static1.pt-content.com/images/pt/2015/05/DSCN0849_zpsadjpr1bd-1.jpg
The welds were ground down and epoxy was brushed on
https://static1.pt-content.com/images/pt/2015/05/DSCN0851_zps1sv5d3dp-1.jpg
Upper cowl fit and welded
https://static1.pt-content.com/images/pt/2015/05/DSCN0854_zpsof24gag8-1.jpg
Fender apron to cowl extensions welded in place and started to test fit the roof after it was sanded and the back side epoxy primed
https://static1.pt-content.com/images/pt/2015/05/DSCN0860_zpsyl9p7kox-1.jpg
dontlifttoshift
05-03-2015, 09:02 AM
Nice! Will there ever be a source for new coupe roof skins?
rusty428cj
05-03-2015, 12:17 PM
That is a new Dynacorn roof and NPD has one but it does not have the side panels
dontlifttoshift
05-03-2015, 01:49 PM
Well shoot, Is that new? I had looked a while back and there wasn't anything readily available, glad it is now!
How does it fit?
rusty428cj
05-29-2015, 07:13 AM
Brian has done a lot of work since I last posted
The rear frame rails had a little rust and needed to be replaced
https://static1.pt-content.com/images/pt/2015/05/DSCN0859_zps14tmldnz-1.jpg
https://static1.pt-content.com/images/pt/2015/05/DSCN0867_zpsfoh60jbn-1.jpg
Test fitting the trunk floor and gas tank
https://static1.pt-content.com/images/pt/2015/05/DSCN0870_zpshgzls9dn-1.jpg
Plug welding the trunk drop offs
https://static1.pt-content.com/images/pt/2015/05/DSCN0873_zpsr6h8lznj-1.jpg
https://static1.pt-content.com/images/pt/2015/05/DSCN0888_zpsbs2beg0p-1.jpg
Fitting the rear package tray and sail panels
https://static1.pt-content.com/images/pt/2015/05/DSCN0885_zpsl3suurp6-1.jpg
The quarter panels were shaped wrong and had to be modified
https://static1.pt-content.com/images/pt/2015/05/DSCN0934_zpsjeqehrgd-1.jpg
https://static1.pt-content.com/images/pt/2015/05/DSCN0938_zpsgodqym4k-1.jpg
Fitting the taillight panel and end caps
https://static1.pt-content.com/images/pt/2015/05/DSCN0939_zpsr3vxrqbb-1.jpg
Left outer wheelhouse welded in place
https://static1.pt-content.com/images/pt/2015/05/DSCN0954_zps49ny4ubk-1.jpg
The right side was to long and had to be modified
https://static1.pt-content.com/images/pt/2015/05/DSCN0955_zpst3w89xgp-1.jpg
Starting to weld the sail panels
https://static1.pt-content.com/images/pt/2015/05/DSCN0969_zps61qgehht-1.jpg
Rear panel welded in place along with the sail panels
https://static1.pt-content.com/images/pt/2015/05/DSCN0978_zps2hlh596m-1.jpg
https://static1.pt-content.com/images/pt/2015/05/DSCN0980_zps69dwomyx-1.jpg
andrewb70
05-29-2015, 08:18 AM
Man....what a labor of love.
rusty428cj
06-07-2015, 08:59 AM
The quarter panels, roof, rear deck panel and taillight panel lined up and welded in place
https://static1.pt-content.com/images/pt/2015/06/DSCN1008_zpsp6vjqdxy-1.jpg
https://static1.pt-content.com/images/pt/2015/06/DSCN1010_zpstdrynf25-1.jpg
https://static1.pt-content.com/images/pt/2015/06/DSCN1014_zps8bo7helu-1.jpg
rusty428cj
06-26-2015, 02:02 PM
The drip rails were removed and welded
https://static1.pt-content.com/images/pt/2015/06/DSCN0982_zpskta0qkag-1.jpg
Welds ground
https://static1.pt-content.com/images/pt/2015/06/DSCN1099_zpsffzm0ere-1.jpg
We still have more work to do inside the car but to stop the surface Brian sanded it down to bare metal
https://static1.pt-content.com/images/pt/2015/06/DSCN1110_zpsqyj4yyzn-1.jpg
I sprayed two coats of SPI black epoxy and it is back in the fab shop
https://static1.pt-content.com/images/pt/2015/06/DSCN1120_zps9kcn3gzz-1.jpg
rusty428cj
07-19-2015, 09:40 AM
Brian is welding the rear floor and modifying the inner wheelhouse for more tire clearance.
https://static1.pt-content.com/images/pt/2015/07/DSCN1000_zpsutcdojfy-1.jpg
https://static1.pt-content.com/images/pt/2015/07/DSCN1044_zpslmpgkm7h-1.jpg
Rear bulkhead panel welded in place
https://static1.pt-content.com/images/pt/2015/07/DSCN1124_zpswbq7nlfp-1.jpg
Welds ground and interior sanded and ready for SPI epoxy
https://static1.pt-content.com/images/pt/2015/07/DSCN1285_zpsh93ntx8e-1.jpg
rusty428cj
08-22-2015, 07:51 AM
We had a major set back. Brian lined up the doors but when he went to line up the fenders and hood he found a major problem. A former employee welded the front end on wrong even though he measured and remeasured before welding. There was very little gap on the left door and a large gap on the right side so the front end had to be cut off. After working on this about two weeks at my expense Brian is satisfied with how it lines up and we should be able to start charging the customer again early next week.
https://static1.pt-content.com/images/pt/2015/08/DSCN1505_zpsw7etyowk-1.jpg
https://static1.pt-content.com/images/pt/2015/08/DSCN1506_zpsqw3y43yp-1.jpg
The replacement outer torque box had to be modified to get it to fit.
https://static1.pt-content.com/images/pt/2015/08/DSCN1509_zpshwrfkidu-1.jpg
wfo guy
08-22-2015, 08:21 AM
^^^ I hate it when that happens!
rusty428cj
08-25-2015, 12:05 PM
The repair is finished and a little epoxy was brushed on to stop the surface rust on the weld
https://static1.pt-content.com/images/pt/2015/08/DSCN1543_zps74dst3li-1.jpg
Fitting the shock tower panels
https://static1.pt-content.com/images/pt/2015/08/DSCN1542_zpsf8dfg9s7-1.jpg
Welding finished just need to start grinding
https://static1.pt-content.com/images/pt/2015/08/DSCN1554_zpsetibj42u-1.jpg
rusty428cj
09-02-2015, 01:38 PM
After Brian finished the front end repair we sent if out to get the engine compartment and undercarriage sand blasted
https://static1.pt-content.com/images/pt/2015/09/DSCN1583_zpsgwszsegk-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1590_zpsztvoyyxg-1.jpg
rusty428cj
09-04-2015, 02:10 PM
Brian fit and welded the Global West subframe connectors.
https://static1.pt-content.com/images/pt/2015/09/DSCN1599_zps0jrxfmiz-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1601_zpsfhmbnnqk-1.jpg
Brian did not like how the torque boxes fit in the rear so he fixed that.
https://static1.pt-content.com/images/pt/2015/09/DSCN1605_zpsijo4ggmw-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1602_zps7gefvsxy-1.jpg
rusty428cj
09-23-2015, 10:59 AM
Epoxy primed the engine compartment and undercarriage
https://static1.pt-content.com/images/pt/2015/09/DSCN1607_zpsi8ydmw37-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1608_zpsc3g81hps-1.jpg
Started the bodywork on the fender aprons
https://static1.pt-content.com/images/pt/2015/09/DSCN1689_zpshbgtqdmb-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1690_zpsyqxoaout-1.jpg
The extra holes in the firewall were patched and the engine compartment epoxy primed
https://static1.pt-content.com/images/pt/2015/09/DSCN1708_zpse3mucbw3-1.jpg
I still wasn't happy with the fender aprons and we did a little bodywork on the firewall
https://static1.pt-content.com/images/pt/2015/09/DSCN1773_zpsx6mnpcqm-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1774_zpsyccy6sj4-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1775_zpsyirhrq8o-1.jpg
One coat of SPI epoxy primer
https://static1.pt-content.com/images/pt/2015/09/DSCN1782_zpsek0hfe0z-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1783_zpsykplqchl-1.jpg
Two coats of SPI Turbo urethane primer
https://static1.pt-content.com/images/pt/2015/09/DSCN1787_zpsitwmuiwv-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1786_zpstaxoesfo-1.jpg
rusty428cj
09-25-2015, 07:00 AM
I never have liked the way Ford just stuck the taillights on the outside of the taillight panel and the owner agreed. He wanted to install 67 taillights but the taillight panel is to small so we are recessing the taillights. He ordered a set of billet bezels from Eddie Motorsports.
The first step was to get the taillights to fit the new taillight panel and trace around it.
https://static1.pt-content.com/images/pt/2015/09/DSCN1792_zpsweazmssz-1.jpg
Brian decided to make a new inner bracket out of thicker metal.
https://static1.pt-content.com/images/pt/2015/09/DSCN1798_zpslur1mubr-1.jpg
This was his first attempt but it was a little to small so he had to make another one out of an old seat riser.
https://static1.pt-content.com/images/pt/2015/09/DSCN1799_zpsb3bspmp4-1.jpg
Test fitting the taillight
https://static1.pt-content.com/images/pt/2015/09/DSCN1801_zpsu98ruxje-1.jpg
His new bracket tack welded in place
https://static1.pt-content.com/images/pt/2015/09/DSCN1802_zpszqdlwkgc-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1804_zpsh0nu2wdc-1.jpg
The top piece is just to hold it in place and will be trimmed.
https://static1.pt-content.com/images/pt/2015/09/DSCN1805_zpsgunilhgx-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1812_zps1zpiznun-1.jpg
The next step will be to make the filler pieces
Motown 454
09-25-2015, 08:22 AM
I love seeing the work you guys do on these projects. Nice job.
chunger
09-25-2015, 09:37 AM
So, you frenched the tail lights?
I assume there will be a box completed on the inside, otherwise wouldn't it let water in?
rusty428cj
09-25-2015, 01:33 PM
Brian cut out the other side and test fit the taillights
https://static1.pt-content.com/images/pt/2015/09/DSCN1822_zpse0ktirbu-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1823_zpsriqbse0i-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1824_zps96y64hou-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1826_zpsfpav6o9f-1.jpg
rusty428cj
09-30-2015, 06:14 AM
Back side welded
https://static1.pt-content.com/images/pt/2015/09/DSCN1838_zpsalxiepzr-1.jpg
This is how Brian filled in the gaps
https://static1.pt-content.com/images/pt/2015/09/DSCN1839_zpsjcf4tdry-1.jpg
https://static1.pt-content.com/images/pt/2015/09/DSCN1841_zpsnyahdqdt-1.jpg
Next he trimmed it and welded it solid
https://static1.pt-content.com/images/pt/2015/09/DSCN1852_zpskonh0iux-1.jpg
Brian isn't finished yet but after grinding it will look like something like this.
https://static1.pt-content.com/images/pt/2015/09/DSCN1851_zpsv9a9wkbx-1.jpg
Z06killinSBF
09-30-2015, 12:24 PM
Totally awesome work, I too thought of frenching my tail lights in instead of the Camaro lights I have now.
RaceFace
10-01-2015, 11:16 AM
Wow, nice work!! Keep the pics comin'!! Tail lights look great!!
rusty428cj
10-06-2015, 09:18 AM
The flares are to small on the early Mustangs so Brian is going to make a little larger flare.
The first thing is to mark where he is going to make his cut and start cutting.
https://static1.pt-content.com/images/pt/2015/10/DSCN1911_zps3b3bu9nq-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1914_zpshf2sye8c-1.jpg
He left it attached at the bottom and brought it out 1 1/4" at the top.
https://static1.pt-content.com/images/pt/2015/10/DSCN1915_zps5w3eq7hh-1.jpg
Next he made a pattern out of poster board and taped it on.
https://static1.pt-content.com/images/pt/2015/10/DSCN1919_zpsw3nlztms-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1918_zpsywu4801d-1.jpg
Next he transferred the pattern to metal and had to make it in sections to get the shape he wanted and started tacking in place
https://static1.pt-content.com/images/pt/2015/10/DSCN1932_zps84bzvwms-1.jpg
He will keep added sections until it is all filled in
https://static1.pt-content.com/images/pt/2015/10/DSCN1935_zpspj713pxx-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1937_zpsperevnw8-1.jpg
cbpldc
10-06-2015, 09:42 AM
Those subtle touches are really bringing that design into a modern era. Very cool and it will look nice when finished.
Chris
Fahrenschnell
10-06-2015, 09:54 AM
Wow. Amazing work.
rusty428cj
10-06-2015, 01:12 PM
Brian is tack welding the last piece
https://static1.pt-content.com/images/pt/2015/10/DSCN1939_zpsksl03ih4-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1940_zpsgrr6fmxa-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1941_zpsd4tpz9ls-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1942_zpscfk8agyk-1.jpg
xj220
10-06-2015, 03:28 PM
Love the fender flares. Although paint and body is down the road, I'm debating doing that or not. I just want a little more room and to get a more tucked look with the wheels. Can't wait to see what comes next!
rusty428cj
10-08-2015, 11:59 AM
Brian finished the outside of the right quarter panel flare.
https://static1.pt-content.com/images/pt/2015/10/DSCN1945_zpsjqzzqgaq-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1958_zpswkz9mkd7-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1960_zpstgjpaw6g-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN1961_zpsztajcyxq-1.jpg
Bossed
10-10-2015, 03:17 AM
I'd love to learn welding tips from Brian. He makes it look so effortless, just top notch.
On a side note, is that a Vega I see hiding in the background ?
JayinMI
10-10-2015, 03:30 AM
I was scrolling through the flare pics, and then stopped and went back when I saw that too. lol
Jay
rusty428cj
10-10-2015, 08:40 AM
Yes it is we started the project at Brian's house and moved it to the shop to finish the bodywork and paint. It belongs to my next door neighbor at the shop.
https://static1.pt-content.com/images/pt/2015/10/64_zpsvv2cz0t0-1.jpg
https://static1.pt-content.com/images/pt/2015/10/65_zpslqsejqdp-1.jpg
Crestronwizard
10-13-2015, 06:58 PM
What size rear tire are you going to run?
rusty428cj
10-14-2015, 06:47 AM
Brian wanted to see how 275 x 18's fit so he borrowed these from another project car
https://static1.pt-content.com/images/pt/2015/10/DSCN1990_zpskztqghuw-1.jpg
This is the owners original 255 x 17's that are now to narrow and will be going on my Mustang II restomod under construction.
https://static1.pt-content.com/images/pt/2015/10/DSCN1994_zpsl5e49v5h-1.jpg
rusty428cj
10-14-2015, 06:48 AM
Probably 275 17 on the rear
cbpldc
10-14-2015, 07:08 AM
Tell me more about this Mustang II. Perhaps its own thread. :)
Chris
rhurley
10-14-2015, 09:13 AM
Are you going to be running a stock width rear end?? Whats the offset on the wheels. Very motivating thread!!!!
rusty428cj
10-14-2015, 09:49 AM
The rear will be stock width. We are going with Rod & Custom coilover rear suspension. We need to get it installed and we can measure for the offset.
rusty428cj
10-23-2015, 09:45 AM
Sprayed a little epoxy to keep it from getting any surface rust
https://static1.pt-content.com/images/pt/2015/10/DSCN2040_zpsc8hfcpsm-1.jpg
Brian is starting on the other side. Bolted on the stone guard and front valance to keep everything lined up.
https://static1.pt-content.com/images/pt/2015/10/DSCN2042_zpsgpvtburt-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN2050_zpsavtdg0ob-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN2052_zpsw60wgtmn-1.jpg
Left side
https://static1.pt-content.com/images/pt/2015/10/DSCN2060_zpsz5f1g7k7-1.jpg
Welds ground
https://static1.pt-content.com/images/pt/2015/10/DSCN2062_zpsosf9dx9t-1.jpg
https://static1.pt-content.com/images/pt/2015/10/DSCN2065_zpsl9fo5wur-1.jpg
Mach1_Ron
10-24-2015, 07:14 AM
Can't wait to see those pics. I run that suspension on the Mach1, still getting it dialed in. Love it so far.
langleylad
10-24-2015, 08:47 AM
Your man sure knows what he's doing ! nice
rusty428cj
11-02-2015, 10:22 AM
https://static1.pt-content.com/images/pt/2015/11/DSCN2103_zpsxj42ekim-1.jpg
Currie 9" with Wilwood brakes
https://static1.pt-content.com/images/pt/2015/11/DSCN2109_zpsx6kgxrzf-1.jpg
Test fitting the rear suspension
https://static1.pt-content.com/images/pt/2015/11/DSCN2115_zpslbbx4anc-1.jpg
https://static1.pt-content.com/images/pt/2015/11/DSCN2117_zpsabg3xn9b-1.jpg
https://static1.pt-content.com/images/pt/2015/11/DSCN2119_zps6dxhzxs4-1.jpg
rusty428cj
11-02-2015, 10:58 AM
The original front fender flare has to be cut out
https://static1.pt-content.com/images/pt/2015/11/DSCN2073_zps739gajzx-1.jpg
https://static1.pt-content.com/images/pt/2015/11/DSCN2074_zpsxkcuhmxm-1.jpg
https://static1.pt-content.com/images/pt/2015/11/DSCN2071_zpsme15uaek-1.jpg
The fenders were sanded to bare metal and epoxy primed
https://static1.pt-content.com/images/pt/2015/11/DSCN2094_zpsrm9b0c6s-1.jpg
https://static1.pt-content.com/images/pt/2015/11/DSCN2096_zps690h7vt7-1.jpg
We did a little bodywork on the inside of the fenders and epoxy primed
https://static1.pt-content.com/images/pt/2015/11/DSCN2106_zpshv98bfue-1.jpg
https://static1.pt-content.com/images/pt/2015/11/DSCN2111_zpsgnbxrmfc-1.jpg
70vertstang
11-03-2015, 10:22 AM
Nice work!!
xj220
11-04-2015, 04:21 PM
I never was really interested in putting flares on my car, but I've been changing over the last couple of months. I must say, those look exactly the way I'd do them if I do them. Can't wait to see them painted up on the finished car. How wide do you think you can go on the front?
Crestronwizard
11-04-2015, 04:39 PM
Looking good. I sprayed bedliner on the inside of my fenders.
rusty428cj
11-07-2015, 11:07 AM
I have the second Rod & Custom rear suspension kit sold on my 1968 Coupe and it fit great. We can get the car real low if we want. The kit has been redesigned and it is a little harder to install and you cannot get it as low as my car.
The upper shock mount now has heim joints because I'm sure not all early Mustangs have the same distance between the frame rails. Tack welded in place
https://static1.pt-content.com/images/pt/2015/11/DSCN2137_zpskfkmzk3h-1.jpg
Upper control arm crossmember and rear end brackets tack welded in place
https://static1.pt-content.com/images/pt/2015/11/DSCN2149_zpsfnjlciqm-1.jpg
Installing the rear coilover shocks
https://static1.pt-content.com/images/pt/2015/11/DSCN2168_zpshdv2mi28-1.jpg
Everything was installed according to the directions and this is the lowest it would go.
https://static1.pt-content.com/images/pt/2015/11/DSCN2171_zpsb3quy3bu-1.jpg
After talking to Rod & Custom they said to turn the lower shock mount over
https://static1.pt-content.com/images/pt/2015/11/DSCN2202_zpsbv6tag7n-1.jpg
This is the ride height now with no weight in the car
https://static1.pt-content.com/images/pt/2015/11/DSCN2187_zpscbjk5cop-1.jpg
rusty428cj
11-12-2015, 12:01 PM
With weight in the car I think the ride height will be about right
https://static1.pt-content.com/images/pt/2015/11/DSCN2208_zpshkvyb3li-1.jpg
Welded the rear valance in place
https://static1.pt-content.com/images/pt/2015/11/DSCN2209_zpsybje0lqd-1.jpg
https://static1.pt-content.com/images/pt/2015/11/DSCN2211_zpsqmrx48l0-1.jpg
Welds ground
https://static1.pt-content.com/images/pt/2015/11/DSCN2210_zpslarvevtp-1.jpg
We wanted to do something different for the exhaust. We cut the exhaust outlets from a 1967 valance but had to make it a little larger to fit our tail pipes
https://static1.pt-content.com/images/pt/2015/11/DSCN2217_zps8dzk8reb-1.jpg
https://static1.pt-content.com/images/pt/2015/11/DSCN2220_zpsbb9dwmng-1.jpg
https://static1.pt-content.com/images/pt/2015/11/DSCN2224_zpsfmg898dk-1.jpg
Welds ground
https://static1.pt-content.com/images/pt/2015/11/DSCN2238_zpsoptdqfht-1.jpg
rusty428cj
12-11-2015, 08:10 AM
Fixing the trunk gap
https://static1.pt-content.com/images/pt/2015/12/DSCN2384_zpsibt1ljnm-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2385_zpsp8cosasf-1.jpg
The owner wanted a spoiler but did not like how tall it was so we lowered the Mustangs to Fear spoiler and end caps about 1". It will be straight with the top of the quarter
https://static1.pt-content.com/images/pt/2015/12/DSCN2421_zpsxkkmutaz-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2422_zpshpbcu0j9-1.jpg
Spoiler cut and test fitting
https://static1.pt-content.com/images/pt/2015/12/DSCN2425_zpsaldvz7cu-1.jpg
cbpldc
12-11-2015, 09:10 AM
Oh that lower spoiler will look really cool! Subtle touches all the way around will make this car look it should have come this way from the factory. Well done!
Chris
rusty428cj
12-29-2015, 02:33 PM
The end caps were bolted, bonded and fiberglass mat added to the quarter panel
https://static1.pt-content.com/images/pt/2015/12/DSCN2490_zpsp60nlakj-1.jpg
The spoiler was bonded to the deck lid and fiberglass mat added
https://static1.pt-content.com/images/pt/2015/12/DSCN2489_zpsg9vkklcd-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2491_zpsztzqaofh-1.jpg
https://static1.pt-content.com/images/pt/2015/12/DSCN2492_zpsqomr1qgm-1.jpg
Bossed
01-03-2016, 07:03 AM
Rusty, looks fantastic, keep the updates coming.
xsboost90
01-03-2016, 12:34 PM
and i thought i was unique in pondering sinking the taillights into the rear panel....should look cool
i once thought of putting some 69 firebird tails in my car- then chip foose did it...i should really work faster.
funbnme
01-07-2016, 12:53 PM
This thread is making me think twice about limiting my project search to a fastback. Great looking mods you're doing.
rusty428cj
01-25-2016, 10:18 AM
I epoxy primed the body
https://static1.pt-content.com/images/pt/2016/01/DSCN2602_zpssw0wl89n-1.jpg
Block sanded and a little more bodywork
https://static1.pt-content.com/images/pt/2016/01/DSCN2608_zps0dgiwphu-1.jpg
https://static1.pt-content.com/images/pt/2016/01/DSCN2616_zpsc3jhanqc-1.jpg
https://static1.pt-content.com/images/pt/2016/01/DSCN2629_zpsx809ct9x-1.jpg
Two coats of SPI Turbo primer
https://static1.pt-content.com/images/pt/2016/01/DSCN2634_zpsjcpaemfj-1.jpg
https://static1.pt-content.com/images/pt/2016/01/DSCN2636_zpsgwdvdewp-1.jpg
https://static1.pt-content.com/images/pt/2016/01/DSCN2639_zpsob2lrwu0-1.jpg
https://static1.pt-content.com/images/pt/2016/01/DSCN2641_zpsdmqh4wvm-1.jpg
rusty428cj
04-16-2016, 02:13 PM
We took the body off the rotisserie and mounted it on a cart so I could finish the taillight panel and rear valance. I block sanded one more time
https://static1.pt-content.com/images/pt/2016/04/DSCN2892_zps5oes1rxm-1.jpg
Epoxy primed
https://static1.pt-content.com/images/pt/2016/04/DSCN2895_zpsowsraj44-1.jpg
We want to test fit everything before paint. Starting installing the Rod & Custom suspension
https://static1.pt-content.com/images/pt/2016/04/DSCN2906_zpspdp7merz-1.jpg
Back on the ground
https://static1.pt-content.com/images/pt/2016/04/DSCN2910_zpsxy47z8kb-1.jpg
Getting ready to install the 347 engine and TKO transmission. Those hoses got to go.
https://static1.pt-content.com/images/pt/2016/04/DSCN2914_zps30zf0zry-1.jpg
Engine and trans installed
https://static1.pt-content.com/images/pt/2016/04/DSCN2922_zpsqaoqehsr-1.jpg
https://static1.pt-content.com/images/pt/2016/04/DSCN2927_zpswgw8ia0o-1.jpg
https://static1.pt-content.com/images/pt/2016/04/DSCN2930_zpstooinuzi-1.jpg
Ididit steering column with a Billet Specialties wheel
https://static1.pt-content.com/images/pt/2016/04/DSCN2932_zpsybd4kqfq-1.jpg
A few more photos
https://static1.pt-content.com/images/pt/2016/04/DSCN2935_zps7trpmxs7-1.jpg
https://static1.pt-content.com/images/pt/2016/04/DSCN2936_zpsaxhgeawm-1.jpg
https://static1.pt-content.com/images/pt/2016/04/DSCN2938_zpstqjzbb9s-1.jpg
wfo guy
04-17-2016, 04:57 AM
Removing shock towers sure makes life easier.
rusty428cj
04-27-2016, 02:12 PM
Brian has the sheetmetal lined up.
https://static1.pt-content.com/images/pt/2016/04/DSCN2962_zpsiofmu7u7-1.jpg
Test fitting the new Stang-Aholics front valance
https://static1.pt-content.com/images/pt/2016/04/DSCN2957_zpsn9xos1cw-1.jpg
https://static1.pt-content.com/images/pt/2016/04/DSCN2963_zpsbuphgkwg-1.jpg
The gas filler will have to be moved down a little because the cap hits the deck lid.
https://static1.pt-content.com/images/pt/2016/04/DSCN2972_zpswejd6ty2-1.jpg
Crestronwizard
04-28-2016, 11:47 AM
Nice progress.
rusty428cj
06-04-2016, 12:03 PM
I have been busy working in the shop and I need to update
I block sanded the fiberglass hood
https://static1.pt-content.com/images/pt/2016/06/DSCN3037_zps2hopvzoa-1.jpg
Sprayed one coat of SPI black epoxy
https://static1.pt-content.com/images/pt/2016/06/DSCN3040_zpszablfzht-1.jpg
Two Coats of SPI Turbo primer
https://static1.pt-content.com/images/pt/2016/06/DSCN3041_zpslbhhpfqy-1.jpg
Block sanded again
https://static1.pt-content.com/images/pt/2016/06/DSCN3043_zpschpfdwxz-1.jpg
Two coats of SPI epoxy
https://static1.pt-content.com/images/pt/2016/06/DSCN3045_zpsubblyais-1.jpg
The fiberglass bumper did not fit our car. The center section did not line up with the lower valance and the bumper was to narrow.
I cut the center out of the bumper and had to modify the holes in the taillight panel to get the bumper lowered.
https://static1.pt-content.com/images/pt/2016/06/DSCN3129_zpsuautgg5z-1.jpg
I used Duraglass to attach the brackets to the bumper. Later I added a couple layers of fiberglass to hold them in place
https://static1.pt-content.com/images/pt/2016/06/DSCN3131_zps0jucjpuo-1.jpg
This shows you have much I need to add to the left side
https://static1.pt-content.com/images/pt/2016/06/DSCN3137_zpsqy6nruny-1.jpg
I added fiberglass to the top to hold it in place
https://static1.pt-content.com/images/pt/2016/06/DSCN3139_zpsrlus7lux-1.jpg
I clamped it to a long piece of angle and added fiberglass on the back side.
https://static1.pt-content.com/images/pt/2016/06/DSCN3140_zpsapduqxn0-1.jpg
I removed the braces and clamps and finished adding fiberglass to both sides and this is how it looks now. I still have to work on the gaps.
https://static1.pt-content.com/images/pt/2016/06/DSCN3159_zpsbxrwwyu4-1.jpg
https://static1.pt-content.com/images/pt/2016/06/DSCN3156_zpsrxzjgan5-1.jpg
rusty428cj
06-09-2016, 02:08 PM
I epoxy primed the bumper and test fit
https://static1.pt-content.com/images/pt/2016/06/DSCN3169_zpstqkbqmna-1.jpg
https://static1.pt-content.com/images/pt/2016/06/DSCN3170_zpspzqxcngx-1.jpg
It still needed a little bodywork
https://static1.pt-content.com/images/pt/2016/06/DSCN3201_zpsorwiecbi-1.jpg
Epoxy primed again
https://static1.pt-content.com/images/pt/2016/06/DSCN3203_zpstg5ie8wa-1.jpg
rusty428cj
06-11-2016, 08:28 AM
This project will be on hold for a little while.
https://static1.pt-content.com/images/pt/2016/06/DSCN3222_zpsxkma1jz0-1.jpg
https://static1.pt-content.com/images/pt/2016/06/DSCN3213_zps1tkuuu58-1.jpg
rusty428cj
08-03-2016, 03:52 AM
We are back working on this project. I had to do a little bodywork on the front of the fenders to get them to line up to the new front valance and epoxy primed.
https://static1.pt-content.com/images/pt/2016/08/DSCN3509_zpsxbkocbyd-1.jpg
Front valance and rear bumper block sanded and epoxy primed
https://static1.pt-content.com/images/pt/2016/08/DSCN3510_zps2l4kdc3v-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3511_zpsoosaedl7-1.jpg
Test fitting one more time
https://static1.pt-content.com/images/pt/2016/08/DSCN3525_zpsor5vmrdb-1.jpg
https://static1.pt-content.com/images/pt/2016/08/DSCN3528_zpszlrqtwzu-1.jpg
gswartz
08-17-2016, 05:46 AM
Nice custom touches. Those fender flairs are some of the best I have seen on a 64-66 mustang!
rusty428cj
10-05-2016, 04:48 PM
We have been working on this doing a lot of little things to make it look right. The hood did not line up with the headlight buckets so I had to add fiberglass to the end of the hood.
https://static1.pt-content.com/images/pt/2016/10/DSCN3461_zpsgtyfqfon-1.jpg
https://static1.pt-content.com/images/pt/2016/10/DSCN3527_zpsjgo58agc-1.jpg
Brian test fit all the door glass, vent windows, quarter windows, windshield and back glass moldings
This area needed a little work
https://static1.pt-content.com/images/pt/2016/10/DSCN3760_zps5gopd0lo-1.jpg
https://static1.pt-content.com/images/pt/2016/10/DSCN3772_zpsfzcs6for-1.jpg
I worked on the body lines
https://static1.pt-content.com/images/pt/2016/10/DSCN3754_zps7qa7rjm0-1.jpg
https://static1.pt-content.com/images/pt/2016/10/DSCN3756_zpstu6hz92i-1.jpg
As you can see in this photo the front valance was a little high and the fender had a low spot that needed bodywork
https://static1.pt-content.com/images/pt/2016/10/DSCN3752_zpswb9ak1fx-1.jpg
https://static1.pt-content.com/images/pt/2016/10/DSCN3776_zpscll0gdkt-1.jpg
In the middle of a lot of block sanding and looking for any imperfections
https://static1.pt-content.com/images/pt/2016/10/DSCN3792_zpsgpi9lwis-1.jpg
rusty428cj
10-19-2016, 12:23 PM
The back of the hood was sanded and epoxy primed
https://static1.pt-content.com/images/pt/2016/10/DSCN3876_zpsb7zckufo-1.jpg
https://static1.pt-content.com/images/pt/2016/10/DSCN3885_zpsqsbj8had-1.jpg
Block sanded the body and epoxy primed
https://static1.pt-content.com/images/pt/2016/10/DSCN3898_zpsguskonn0-1.jpg
https://static1.pt-content.com/images/pt/2016/10/DSCN3901_zpsbepafoai-1.jpg
https://static1.pt-content.com/images/pt/2016/10/DSCN3908_zpss2ceqsqi-1.jpg
The trunk was sanded and epoxy primed
https://static1.pt-content.com/images/pt/2016/10/DSCN3936_zpss6ipog9e-1.jpg
https://static1.pt-content.com/images/pt/2016/10/DSCN3945_zpsyubj2xk2-1.jpg
The engine compartment was sanded and epoxy primed
https://static1.pt-content.com/images/pt/2016/10/DSCN3938_zpstvud6uff-1.jpg
https://static1.pt-content.com/images/pt/2016/10/DSCN3941_zpsphpnjjhw-1.jpg
rusty428cj
10-22-2016, 04:21 AM
Test fitting the Stang-Aholics upper and lower grille
https://static1.pt-content.com/images/pt/2016/10/DSCN3997_zpsg59crxce-1.jpg
https://static1.pt-content.com/images/pt/2016/10/DSCN3998_zpsas5ndqru-1.jpg
rusty428cj
12-10-2016, 12:31 PM
I need to get you caught up on the progress we have made. The body is back on the rotisserie getting ready for paint.
https://static1.pt-content.com/images/pt/2016/12/DSCN4092_zpsbxn4by0y-1.jpg
https://static1.pt-content.com/images/pt/2016/12/DSCN4095_zpsqwjo4chf-1.jpg
Epoxy primed the fenders and hood
https://static1.pt-content.com/images/pt/2016/12/DSCN4118_zpsdrr1ejbs-1.jpg
https://static1.pt-content.com/images/pt/2016/12/DSCN4121_zps12t4rhc4-1.jpg
Sanding the interior getting it ready for Lizard Skin
https://static1.pt-content.com/images/pt/2016/12/DSCN4127_zpsaa2chple-1.jpg
Epoxy primed
https://static1.pt-content.com/images/pt/2016/12/DSCN4138_zps5mdgv10e-1.jpg
Sanded the back of the hood and deck lid, epoxy primed, sprayed 3 coats of Pepper Gray and the next day 3 coats of SPI Universal Clear
https://static1.pt-content.com/images/pt/2016/12/DSCN4193_zpsdzdxtkug-1.jpg
https://static1.pt-content.com/images/pt/2016/12/DSCN4196_zpsn1niwnch-1.jpg
I painted the headlight buckets
https://static1.pt-content.com/images/pt/2016/12/DSCN4236_zps1dnlsmvk-1.jpg
https://static1.pt-content.com/images/pt/2016/12/DSCN4239_zpskl9wjelu-1.jpg
wfo guy
12-11-2016, 06:30 AM
Very good. :)
rusty428cj
12-28-2016, 02:22 PM
Undercarriage sanded and epoxy primed
https://static1.pt-content.com/images/pt/2016/12/DSCN4259_zpspfdavaxf-1.jpg
https://static1.pt-content.com/images/pt/2016/12/DSCN4262_zpsz60ibaf1-1.jpg
Doors and fenders epoxy primed wet sanded and painted pepper gray
https://static1.pt-content.com/images/pt/2016/12/DSCN4338_zps2bim0feg-1.jpg
https://static1.pt-content.com/images/pt/2016/12/DSCN4357_zpsynmjmhil-1.jpg
https://static1.pt-content.com/images/pt/2016/12/Door_zps68fijoyz-1.jpg
https://static1.pt-content.com/images/pt/2016/12/Fender_zpskeaokddv-1.jpg
rusty428cj
01-28-2017, 12:11 PM
Final taping before paint
https://static1.pt-content.com/images/pt/2017/01/DSCN4415_zps9begmeuw-1.jpg
https://static1.pt-content.com/images/pt/2017/01/DSCN4419_zpskn5hgopp-1.jpg
https://static1.pt-content.com/images/pt/2017/01/DSCN4420_zpsu3wal04y-1.jpg
Epoxy primed
https://static1.pt-content.com/images/pt/2017/01/DSCN4424_zpso4to7e19-1.jpg
https://static1.pt-content.com/images/pt/2017/01/DSCN4423_zpszar6tgff-1.jpg
https://static1.pt-content.com/images/pt/2017/01/DSCN4426_zps3j01phwc-1.jpg
https://static1.pt-content.com/images/pt/2017/01/DSCN4427_zpsnituppzz-1.jpg
HotRod47
01-29-2017, 02:26 AM
Love this project. Coming out very nice!
wfo guy
01-29-2017, 05:00 AM
I can only imagine how nice it is to have a rotisserie to paint with. I'm surprised that someone hasn't made an electric drive for one so you could rotate to get everything to it's best possible angle to paint. Car is looking good.
rusty428cj
02-04-2017, 12:00 PM
After sanding we found a couple of small imperfections I wasn't happy with so I fixed them and epoxy primed again. It will be ready for paint after a little wet sanding with 600.
https://static1.pt-content.com/images/pt/2017/02/20170204_141517_resized_zpskghagsde-1.jpg
https://static1.pt-content.com/images/pt/2017/02/20170204_141456_resized_zpswykzl2tj-1.jpg
rusty428cj
02-11-2017, 10:57 AM
Brian covering the engine compartment the other day getting it ready for pepper gray.
https://static1.pt-content.com/images/pt/2017/02/DSCN4539_zpszvsuaotu-1.jpg
Yesterday I sprayed 3 coats of ProSpray pepper gray
https://static1.pt-content.com/images/pt/2017/02/20170210_161923_resized_zpsfztnmspg-1.jpg
https://static1.pt-content.com/images/pt/2017/02/20170210_161918_resized_zps9tdd18km-1.jpg
https://static1.pt-content.com/images/pt/2017/02/20170210_161942_resized_zps9u33kf8o-1.jpg
https://static1.pt-content.com/images/pt/2017/02/20170210_161955_resized_zps4nw8jgnt-1.jpg
jfreakofkorn
02-11-2017, 11:29 AM
interesting colour
rusty428cj
02-11-2017, 01:25 PM
Today I sprayed a couple of coats of SPI Universal clear. The next step will be to wet sand and lay out the stripes and spray more clear.
https://static1.pt-content.com/images/pt/2017/02/20170211_154211_resized_zpsaqkesigv-1.jpg
https://static1.pt-content.com/images/pt/2017/02/20170211_154129_resized_zps1svjx7nk-1.jpg
https://static1.pt-content.com/images/pt/2017/02/20170211_154238_resized_zpsgegzgrca-1.jpg
https://static1.pt-content.com/images/pt/2017/02/20170211_154225_resized_zpswshhhngn-1.jpg
Wldtang
02-11-2017, 05:41 PM
What color stripes?
wyattroa
02-11-2017, 07:36 PM
I am loving that color paint!
rusty428cj
02-12-2017, 08:54 AM
What color stripes?
Black metallic
rusty428cj
06-12-2017, 11:20 AM
Brian started laying out the stripes on the body
https://static1.pt-content.com/images/pt/2017/06/4612_zpsyckt2bcf-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4621_zpsrqamy2q3-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4626_zpsfgkyvtbt-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4631_zpscyqwj5yj-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4633_zpsdf3saoe2-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4624_zpskynfyy7r-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4627_zpszhlcb9m6-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4628_zpskqpuydvf-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4634_zpsmuriixwv-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4638_zpskzuzl7si-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4641_zpsvxlppicu-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4642_zpsxrzfyfob-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4630_zpsukvc5frz-1.jpg
Five coats of clear wet sanded and buffed
https://static1.pt-content.com/images/pt/2017/06/4649_zpsc80e7mob-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4648_zpsdoxlj0x1-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4651_zpsnemnnqwa-1.jpg
https://static1.pt-content.com/images/pt/2017/06/4652_zpshdbkjsjq-1.jpg
wfo guy
06-12-2017, 02:28 PM
That looks great. What's the story on the red, white and blue fastback?
rusty428cj
06-12-2017, 04:54 PM
I raced it in SS/GA back in the 70's and set the NHRA record in 1971 and 1974. Won class at Pomona in 1972. Quit racing it after the 1974 season. Restored it close to the way it was raced in the 70's in 2005. At this time the engine is out being rebuilt to race in Stock.
MSTSFabbed
06-13-2017, 12:09 PM
Hey Rusty,
I always enjoy following you builds. I've learned a ton from watching you and Brian work.
Can you help me understand your spray up order? Is there a benefit to spraying clear over the initial base, then stripes, then more clear? I've been working towards paint with a boss style hood/fender stripe and in my head base, stripe, then bury in clear made sense.
Thanks! Keep up the good work!
rusty428cj
06-14-2017, 04:08 AM
Hey Rusty,
When you remove the tape there is residue that needs to be cleaned but the big thing is Brian wants everything perfect and that requires a lot of measuring and pencil marks that need to be scuffed before you can clear. If you don't care that the stripes aren't 2" wide and have a 2" gap everywhere you might be able to get by without the clear over the base.
MSTSFabbed
06-15-2017, 11:45 AM
Oh ok, I can see that! Good points to consider, thank you.
Brian did a fantastic job, it looks incredible!
rusty428cj
09-02-2017, 11:22 AM
We finally sprayed the stripes on the body after Brian did a lot of taping
https://static1.pt-content.com/images/pt/2017/09/4669_zpsjpycjdt9-1.jpg
https://static1.pt-content.com/images/pt/2017/09/4672_zps7lxq81rj-1.jpg
Three coats of metallic black
https://static1.pt-content.com/images/pt/2017/09/4671_zpstfyzyxww-1.jpg
Ready for clear
https://static1.pt-content.com/images/pt/2017/09/4674_zpshtquqbue-1.jpg
https://static1.pt-content.com/images/pt/2017/09/4675_zpse7w6ag17-1.jpg
Five coats of clear
https://static1.pt-content.com/images/pt/2017/09/4681_zpslecibav7-1.jpg
https://static1.pt-content.com/images/pt/2017/09/4684_zpsm12prlgy-1.jpg
https://static1.pt-content.com/images/pt/2017/09/4682_zpsns3mzyix-1.jpg
craigF
09-02-2017, 02:10 PM
Love your builds.
Gives me inspiration after frustration. If only i had half of the skills of you guys.
Looks great
craigF
09-02-2017, 02:12 PM
Where are your parts sourced from. The parts we get in Australia are always bad. It's not a case of will this part fit it's always, I wonder how much i will have to reshape this part!!
rusty428cj
09-02-2017, 03:44 PM
Dynacorn but they still usually need work to get the gaps right.
Bossed
09-04-2017, 01:28 AM
Rusty, the paint job looks amazing !! You fellas never cease to impress, thanks for sharing.
rusty428cj
09-20-2017, 11:59 AM
I painted the stripes on the rear bumper
https://static1.pt-content.com/images/pt/2017/09/4689_zpsyrsm1ihc-1.jpg
Brian wet sanded the body
https://static1.pt-content.com/images/pt/2017/09/4693_zpsfz0skhuj-1.jpg
We are going to put it out in the sun for a few days to get all the solvents out.
https://static1.pt-content.com/images/pt/2017/09/4694_zpsulpqd8hl-1.jpg
Z06killinSBF
09-21-2017, 09:58 AM
Looks great, Is it weird that I'm impressed with how tight you got the plastic sheets? haha
rusty428cj
10-15-2017, 08:49 AM
The undercarriage was sprayed with Lizard Skin and the next day I sprayed a couple coats of SPI black epoxy
https://static1.pt-content.com/images/pt/2017/10/4711_zpscqkusr45-1.jpg
https://static1.pt-content.com/images/pt/2017/10/4715_zpsvcpthb1d-1.jpg
Brian finished buffing
https://static1.pt-content.com/images/pt/2017/10/4723_zpsl1pxd5e4-1.jpg
https://static1.pt-content.com/images/pt/2017/10/4724_zpsjwaklgnv-1.jpg
https://static1.pt-content.com/images/pt/2017/10/4729_zpsyek0macw-1.jpg
wfo guy
10-15-2017, 04:25 PM
Very nice! :)
rusty428cj
10-16-2017, 04:05 AM
Brian installed the Rod & Custom front suspension
https://static1.pt-content.com/images/pt/2017/10/4728_zpszx8pqvt5-1.jpg
https://static1.pt-content.com/images/pt/2017/10/4734_zpssv5yp2sv-1.jpg
https://static1.pt-content.com/images/pt/2017/10/4738_zps9xh9d31f-1.jpg
He also installed Rod & Custom rear suspension
https://static1.pt-content.com/images/pt/2017/10/4736_zpsiaejvzr0-1.jpg
https://static1.pt-content.com/images/pt/2017/10/4739_zpsoioxrvl7-1.jpg
https://static1.pt-content.com/images/pt/2017/10/4744_zps9vsumm7s-1.jpg
https://static1.pt-content.com/images/pt/2017/10/4745_zpsy23ovzyq-1.jpg
wfo guy
10-16-2017, 04:43 PM
Just lovely. :)
1968CamaroSS_Sam
10-17-2017, 01:11 PM
The car is looking really good.
Bossed
10-22-2017, 07:40 AM
You fellas sure do top shelf work !!
craigF
10-26-2017, 09:01 AM
Hi Rusty, love yours and Brian’s work in fact one of your builds inspired me to remove the roof on my 67 coupe to check for rust. Glad I did.
It’s about time to refill the sail panel joint and I was wondering if you guys re lead them or just use filler?
Filler has come a long way since 1967 and obviously easier to use.
Craig.
rusty428cj
10-27-2017, 04:47 AM
Craig.
I'm glad I could help. Brian welds a patch panel over the joint so we don't have to use as much filler.
https://static1.pt-content.com/images/pt/2017/10/123-1.jpg
https://static1.pt-content.com/images/pt/2017/10/1251-1.jpg
rusty428cj
11-24-2017, 09:47 AM
Dynamat
https://static1.pt-content.com/images/pt/2017/11/4750_zpsepi41n9f-1.jpg
https://static1.pt-content.com/images/pt/2017/11/4754_zpsq6uudboo-1.jpg
Changed the wheels
https://static1.pt-content.com/images/pt/2017/11/4763_zpslrgotauu-1.jpg
https://static1.pt-content.com/images/pt/2017/11/4765_zpse1tubwoq-1.jpg
Power windows
https://static1.pt-content.com/images/pt/2017/11/4767_zps2pwk2yzb-1.jpg
Painted the bumper and lined up
https://static1.pt-content.com/images/pt/2017/11/4766_zpsintdwhrk-1.jpg
Test fitting the battery and radiator
https://static1.pt-content.com/images/pt/2017/11/4771_zpsxmgjivdq-1.jpg
Test fitting the Mustang to Fear console
https://static1.pt-content.com/images/pt/2017/11/4768_zps9w6nj9zt-1.jpg
Amp mounted under the package tray
https://static1.pt-content.com/images/pt/2017/11/4769_zps2eturijz-1.jpg
We could not find a power brake booster that would clear the hydraulic clutch master cylinder so we went with the Hydratech Braking System.
https://static1.pt-content.com/images/pt/2017/11/4774_zpsxqw5pdue-1.jpg
We still could not get the hydraulic clutch master cylinder to clear but found one from Modern Drive line that clears. Talked to Hydratech and they said have never had a problem but there was no way it would clear on our car. Looked at a couple of other 65 - 66 Mustangs in the shop and found that the aftermarket firewall on our project was not the same as the original one and that was our problem.
https://static1.pt-content.com/images/pt/2017/11/4772_zpswxub9trh-1.jpg
https://static1.pt-content.com/images/pt/2017/11/4777_zpschtqgafk-1.jpg
It's a tight fit but clears
https://static1.pt-content.com/images/pt/2017/11/4776_zpsiuviomjy-1.jpg
Motown 454
11-24-2017, 03:42 PM
Wow nice wok guys.
wfo guy
11-24-2017, 04:51 PM
Every change may have a surprise. :) Looking good, guys.
Bossed
11-25-2017, 05:49 AM
Car is going to look amazing when finished. Great job !!
Crestronwizard
11-26-2017, 06:08 PM
Great progress!
rusty428cj
01-27-2018, 11:58 AM
I fabricated the brake lines.
https://static1.pt-content.com/images/pt/2018/01/481_zps2hdntdzc-1.jpg
https://static1.pt-content.com/images/pt/2018/01/471_zpsggzlsrpp-1.jpg
https://static1.pt-content.com/images/pt/2018/01/470_zps7ewdix4l-1.jpg
Almost ready to install the engine
https://static1.pt-content.com/images/pt/2018/01/506_zpsoqyynful-1.jpg
The 347 engine was started on a test stand with a carburetor to check for any leaks or problems
https://static1.pt-content.com/images/pt/2018/01/510_zpslbs1da3c-1.jpg
Installing the engine
https://static1.pt-content.com/images/pt/2018/01/513_zpsmjeri4sz-1.jpg
We still have to install the transmission
https://static1.pt-content.com/images/pt/2018/01/508_zpsmkwe3sdj-1.jpg
Holley Sniper EFI and JBA headers. The plug wires will be changed to black Ford Racing
https://static1.pt-content.com/images/pt/2018/01/520_zpstlhz1xi5-1.jpg
https://static1.pt-content.com/images/pt/2018/01/522_zpstabg7op9-1.jpg
https://static1.pt-content.com/images/pt/2018/01/523_zpsgqyqxxyu-1.jpg
andrewb70
01-27-2018, 12:25 PM
I like the red plug wires. It's always nice to have a pop of color in the engine bay. If you make everything just shades of black, white, gray, and shiny, it becomes monotone and a little boring.
HotRod47
01-28-2018, 04:10 AM
The car is looking really good!!
wfo guy
01-28-2018, 05:05 AM
Is this your 1st sniper install? I'm curious if there's any reasons to buy that versus the Fitech. Cars looking real nice.
rusty428cj
01-29-2018, 04:34 AM
Yes the owner bought it.
craigF
02-03-2018, 12:42 PM
Hi Rusty. Love the work you do.
Hoping you could give me a little advice .
Have replace the quarters on my 67 Coupe and am wondering what to fill the seam with. Do you lead wipe them again as per the original style or use a filler material. If so what’s the best material to use.
Also does Brian fully weld the qtr seam or jus plug it.
Any advice would be a help
Craig.
rusty428cj
02-24-2019, 09:14 AM
Craig.
Brian welds a patch over the seam. We use Duraglass first followed with 3m Platinum.
Fully welds only does a small weld at a time and cools with the air hose.
rusty428cj
02-24-2019, 09:32 AM
Brian installed an electric E brake
https://static1.pt-content.com/images/pt/2019/02/656a_zpsjdjrbofc-1.jpg
AC lines fabricated and installed
https://static1.pt-content.com/images/pt/2019/02/645_zps5m012mxf-1.jpg
https://static1.pt-content.com/images/pt/2019/02/647_zpsnx8j0cvg-1.jpg
https://static1.pt-content.com/images/pt/2019/02/646_zpskudaewix-1.jpg
https://static1.pt-content.com/images/pt/2019/02/648_zpsxeajumu2-1.jpg
https://static1.pt-content.com/images/pt/2019/02/649_zpscohci1zu-1.jpg
wfo guy
02-25-2019, 07:21 AM
Very nice. :)
rusty428cj
05-31-2019, 03:42 PM
We finished this a few months ago and I forgot to update.
https://static1.pt-content.com/images/pt/2019/05/689_zpss3aeavyo-1.jpg
https://static1.pt-content.com/images/pt/2019/05/695_zpsopakqssg-1.jpg
https://static1.pt-content.com/images/pt/2019/05/696_zpsmvgamau4-1.jpg
https://static1.pt-content.com/images/pt/2019/05/699_zpsphx0izez-1.jpg
https://static1.pt-content.com/images/pt/2019/05/697_zpsjo4g7qon-1.jpg
https://static1.pt-content.com/images/pt/2019/05/700_zpszgrb1iix-1.jpg
https://static1.pt-content.com/images/pt/2019/05/702_zpsh0vekxqq-1.jpg
wfo guy
06-02-2019, 03:06 PM
Way cool, Rusty. :)
rusty428cj
08-11-2019, 03:20 PM
I heard this rumble go by the house and I was surprised to find out it was Chad with his 66 Mustang. I haven't heard from him since he picked it up and he has driven it over 500 miles and is very happy. He had the windows tinted and the trunk finished.
https://static1.pt-content.com/images/pt/2019/08/705_zpsfszjdbyh-1.jpg
https://static1.pt-content.com/images/pt/2019/08/704_zpsgiqxaora-1.jpg
https://static1.pt-content.com/images/pt/2019/08/707_zpsqocuws4a-1.jpg
https://static1.pt-content.com/images/pt/2019/08/708_zps3hvjt0ju-1.jpg
https://static1.pt-content.com/images/pt/2019/08/709_zpsagtnjbfr-1.jpg
wfo guy
08-11-2019, 03:30 PM
I hope he lit'em up when he left. :)
Bullitt67
08-18-2019, 03:15 PM
Great looking car! Been wanting to do a parking brake like that myself. Are you happy with it?
Also, what's it run to do a carpeted trunk like that? Been meaning to do it for a long time, but other priorities keep bumping it down the list...
Z06killinSBF
08-21-2019, 09:28 AM
TMI makes a carpet kit like that for these
rusty428cj
12-05-2019, 07:10 AM
Chad's Mustang is featured in the December issue of Mustang Times
169895169896169897169898169899169900169901169902
