View Full Version : Rear End Advice
JAVO1991
04-06-2015, 01:59 PM
hello fellas i have a 68 Firebird that im building and i have what i think is a 8.2 10 bolts with 355s and i wanna know if this thing can hold a Ls 376/525 T56 combo
Schwartz Performance
04-06-2015, 02:31 PM
What's the intended use? Drag use ever?
-Dale
68Formula
04-06-2015, 02:40 PM
The BOP 8.2s are a little stronger than the Chevy ones. If you're not planning on slicks or drag radials, you're probably ok.
JAVO1991
04-06-2015, 03:15 PM
is only for street use and im just kind of lost because this is my first project ever
Windycity1
04-06-2015, 04:04 PM
If you can find a good deal on a 12 bolt that's the route I would take. If money is tight clean up the 10 bolt and run it until it breaks.
nokones
04-07-2015, 06:48 AM
If you re just grocery getting with street rubber and not mashing the gas a lot, you should be OK. I would go through the diff just to be on the safe side.
