joshtownsend
04-06-2015, 10:40 AM
Would like to sell my 1968 pro touring Firebird. Details on the car are as follows. I am looking for a quick sell but I am not going to give it away. Car has been done with the thought that I would keep it, there fore, the best parts and work was done on it. Car does have a hood that will go with it and can be put on if needed/wanted. I personally like the "no hood" look, but that's just me.
$28k OBO
1968 firebird
body has been redone, panels been replaced
Painted a single stage Flat "hot rod" black
Body work seems to be done very well.
Sub frame was repainted.
The side firebird emblems were shaved as well as little other details.
Car is on an airbag setup. I bought the car as a rolling chassis so i do not have picture prior to this.
Drive train is a LQ4 with 4l80 trans, had around 70k miles from a truck
Holley oil pan, motor mounts and headers where used, trans mount was made and acc brackets are from Kiwk proframnce.
Has a mild cam comp cam 220/224 with new dual valve springs, retainers and ls2 lifters
Under drive crank pulley
Has Kiwk prefromance lsx AC bracket with a Saden compressor already mounted. but do not have AC
Has power steering
Full 6an SS fuel lines with areomotive FPR
New areomotive F body fuel tank with a 340 pump built in.. This was a complete unit from them, bolt in and go.
Professional products intake with a fast 92mm TB
Polished valve covers and coils relocated toward the front of the car
Has lokar gas pedal with all polished accessories to make it work
Installed the Dakota digital gauges with the BIM 1 for LS motors to make everything work correctly.
Interior is all new form classic car industry.
its the standard interior with new window regulators
Has new weather stripping and new clear back glass.
The side and front are OEM but the front oem has a small crack on the inside of the windshield on the passenger side lower part where it crack a little bit getting it out. I was going to replace it but its done cracking and it is OEM, so i reinstalled it and had no trouble since.
Front and back glass trim is OEM from what I can tell.
I modified the center console to accept a B and M hammer shifter and had it recover in black leather.
Seats were redone with classic seat covers, repairs were made where they needed it.
I only with back with lap belts, so no 3 point harness here.
Battery is located in the back.
Any other questions, please contact me directly. thanks
$28k OBO
1968 firebird
Has power steering
