shmoov69
04-05-2015, 08:05 PM
Ok, first the Camaro is still running and running well so that is good! LoL!
Second, there seems to be a tad bit of slop in the rear when I let off the gas and I'm thinking that maybe a rod end has loosened up since it has happened before. Albeit the previous ones were the "economy" ones and I replaced them with the good ones from speedway. It's been several years and two larger turbos later, but I pulled the TQ arm and lo and behold the upper rod end has egg shaped. Any idea where I can get some higher quality ends than the ones I have? No, I don't have the PN from these since its been so long. Better yet, which rod ends should I be using for the upper TQ arm mount in a higher hp car?
thanks!
thanks!
