UMI Performance
03-31-2015, 04:43 AM
UMI Designed Bolt-in Front Coilover kit for 1993-2002 GM F-Body
P/N 2048-300, 2048-350, 2048-450, 2048-550
Priced at $679.99/set
UMI Performance, Inc. is pleased to announce the availability of our new P/N 2048 F-body front coilover kit. The rubber shock mount tends to rust out and allow unwanted movement while being costly to replace. The 2048 replaces that unit with a bolt-in, race proven double shear upper mount and bearing mounted shock. The 2048 brackets capture a Viking double adjustable coilover specific shock and a 300, 350, 450 and 550 lb-in spring. We recommend 550 for auto-x and road racing, 450 for hot street and corner carving, 350 for general use and 300 for drag specific use. Upgrades include Crusader Pro-Tour specific valvings. Included lower t-bar fits in GM factory or UMI standard mount lower a-arms making this a true bolt in coilover. This kit is generally used for 1-3” lowering from factory location and does not make any permanent changes to the upper spring mount or chassis. All UMI products are manufactured tested and raced out of Philipsburg, PA and always use US materials.
WEBSITE LINK HERE (http://umiperformance.com/catalog/index.php?main_page=product_info&cPath=7_137_100_405&products_id=913)
https://static1.pt-content.com/images/pt/2015/03/2048xxxa_LRG-1.jpg
https://static1.pt-content.com/images/pt/2015/03/2048xxxac_LRG-1.jpg
