View Full Version : Spring Axles on enclosed car haulers?
BuddyP
03-28-2015, 07:11 AM
Anybody here running spring axles on your enclosed car haulers? Thoughts? Do you wish you upgraded to torsion?
How does it pull empty vs loaded?
I like the idea of having equal loading with springs but always hear of noise and too much bounce depending on who you talk to.
TheJDMan
03-28-2015, 01:33 PM
Are you looking to buy a new enclosed trailer? I have owned both spring and torsion trailers. Typically a leaf spring trailer ride is a little more harsh than the torsion suspension. Normally you see the cheap cargo trailers and flat bed equipment trailers equipped with leaf spring suspension while all the more expensive better quality car trailers have Torsion axles. The big difference is that a spring suspension requires more maintenance than torsion axle simply because there are more moving parts to wear but the parts are replaceable. On the other hand if a torsion axle wears out there is no repairing it you must replace the entire axle. As for equal loading of tandem axles that is simply a matter of proper hitch height adjustment so the trailer sets level when hitched to the tow vehicle.
BuddyP
03-28-2015, 09:54 PM
Are you looking to buy a new enclosed trailer? I have owned both spring and torsion trailers. Typically a leaf spring trailer ride is more harsh than the torsion suspension. Normally you see the cheap cargo trailers and flat bed equipment trailers equipped with leaf spring suspension while the more expensive better quality car trailers have Torsion axles. That should tell you something about ride quality. As for equal loading of both axles that is simply a matter of proper hitch height adjustment so the trailer sets level when hitched to the tow vehicle.
I've only owned torsion axles in the past, no issues, just curious in general. But yes I am going to get another trailer very soon.
howehot
03-31-2015, 10:43 AM
I've pulled both and didn't notice a difference. 24' enclosed with leaf springs, 28' with torsion.
MonzaRacer
05-03-2015, 09:51 PM
Biggest issue is torsion axles wear out, literally.
Worked at truck and auto shop, and they broke all the time in work trailers, where as most guys only changed load ratings and electric brakes on leaf trailers. But keeping time inspected and serviced either work fine.
I personally had ideas of building a trailer up to run air ride, tied into rear of truck. But its still a dream.
