View Full Version : Will These Fit A 72 Nova?
72_Nova
03-23-2015, 01:56 PM
Trying to find some wheels to fit my 72 and was wondering if you guys could help. Below are the links
http://dallas.craigslist.org/ndf/pts/4935518877.html
http://dallas.craigslist.org/ndf/pts/4944297807.html
I didn't know till today about how some bmw wheels fit but idk which ones will work. any info would be appreciated.
This is what im working with btw...
https://static1.pt-content.com/images/pt/2015/03/10uo7Gj-1.jpg (http://imgur.com/fIbycnK)
70TWO NOVA
03-23-2015, 02:35 PM
bolt pattern is the same. you would just have to figure out the backspacing/offset. Worst case you would need spacers
2ABodies1FBody
03-23-2015, 05:17 PM
I can't help you any on the wheels, but what satin black paint is that? Looks great!
72_Nova
03-24-2015, 05:48 AM
Its a wrap just finished it myself. I used 3M 1080 Satin black s12
72_Nova
03-24-2015, 06:36 AM
on the box is says off set 32
2ABodies1FBody
03-24-2015, 06:03 PM
03-25-2015, 11:06 AM
18x10 32mm offset is 6.76" back space. Your going to need a 1" adapter to put you at 5 3/4" BS. Run an adapter for 5x 4 3/4" hub pattern and a 5 x 120mm wheel pattern. If I remember right you will need a 1 1/4" adapter for the fronts, although I cannot read the lower box.
Nova will take 5 1/2" - 5 3/4" back space no problem. I would recommend measuring your tubs to be sure as all cars are different.
Tip, its easier to modify the inboard area than the quarter panel.
72_Nova
03-25-2015, 11:14 AM
thx what about a 18x9.5 22mm offset rear and 18x8 22mm offset front. Thses are the tsw Valencia wheels
WallaceMFG
03-25-2015, 11:37 AM
Keep in mind that the bolt pattern is different, you either need to run adapters or get the wheels modified, or else your lug nuts may come loose. I put TSW wheels on my Chevelle, but I got the bolt pattern fixed so no spacers.
The 18 x 9.5 with 22mm offset comes out to 6" BS, so you may still have to run spacers.
72_Nova
03-25-2015, 01:25 PM
so whats ideal cause everything im finding is in mm and not inches
