View Full Version : 68-72 GM A-Body Spindles...What's the difference between disc & drum???
71Monty
03-21-2015, 11:26 AM
Hello folks I've been searching for a while and having trouble finding a definite answer. I'm in the process of upgrading my factory front disc brakes on my 1971 Monte Carlo to some F-Body front disc brakes from a 2000 Camaro. I see a lot of drum to disc but not disc to disc swaps.
What's the difference between a factory drum spindle and a factory disc spindle?
I have front drum hubs that I need to have turned down I need to know do I have to get drum spindles or can I use my factory disc ones.
https://static1.pt-content.com/images/pt/2015/03/16884022312_440b669405_z-1.jpg (https://flic.kr/p/rHZ2AY)
https://static1.pt-content.com/images/pt/2015/03/16697590998_6b41f60af1_z-1.jpg (https://flic.kr/p/rrvw4Y)
Typhoon1015
03-21-2015, 12:12 PM
Disc spindle needs a spacer for the top bolt on the LS1 bracket to line up straight with the bottom bolt hole. Drum hubs fit fine on the disc spindle, just have to turn them down the for new rotor to fit over.
71Monty
03-23-2015, 03:38 PM
Typhoon1015 you're right. I test fitted the drum hubs and they fit perfectly.
HomeBuilt
03-23-2015, 05:28 PM
Hold on, so are you saying I can use the stock brakes off a 2000 SS Camaro on my 69 Chevelle factory drum spindle with no adapter bracket?
71Monty
03-24-2015, 06:35 PM
No. You still need a bracket, I wasn't sure about the spindle.
