View Full Version : GM hood hinge mod
70TWO NOVA
03-18-2015, 09:21 PM
Has anyone modified a GM musclecar hood hinge to use a hydraulic cylinder instead if a spring? Similar to the aftermarket ones out there now a days?
WallaceMFG
03-18-2015, 09:39 PM
I was looking into doing something like that, Id like to know too. I might try seeing if I can build my own hinges out of some aluminum, I can't afford to buy them haha
70TWO NOVA
03-19-2015, 06:14 AM
Im right there with you lol
dynodanmanda79
07-19-2015, 05:47 PM
Like this?
https://static1.pt-content.com/images/pt/2015/07/imagejpg1_zpsbphhukfn-1.jpg (http://s180.photobucket.com/user/dynodanmanda79/media/image.jpg1_zpsbphhukfn.jpg.html)
70TWO NOVA
07-19-2015, 08:17 PM
Yes, but on the older style hood hinges from first gen camaros and second gen Novas
Like this?
JustJohn
07-20-2015, 04:32 AM
Like this?
[/URL]
Old style hinges are 4-bar linkages to swing the rear edge of the hood out and away from the car. You can't lift from the same pivot points because changing the arm length would change the arc of the linkage during hood opening.
t72ss402
07-20-2015, 04:24 PM
That looks like you are doing this on a G-Body? What parts are you using?
Tim.
70TWO NOVA
07-20-2015, 07:16 PM
I know it's been done on the old style hinges before. I've seen pics of it
cactuss4
07-20-2015, 08:14 PM
I have them on my 66 Chevelle ..115311 Unless I'm misunderstanding
70TWO NOVA
07-20-2015, 08:36 PM
I'm looking to see if anyone has retrofitted stock hinges with the cylinders. I know there are plenty of aftermarket aluminum ones out there but I prefer to use the ones I have.
cactuss4
07-20-2015, 09:25 PM
Ahh roger, read that this time through, my mistake.
JustJohn
07-21-2015, 03:16 AM
I didn't disagree. It just can't be done per the original picture.
67 455 Bird ragtop
07-21-2015, 05:53 AM
I've seen people do the trunk by mounting the bottom of the cylinders to the floor of the trunk. This allowed the cylinders to work in an almost vertical position. I was wondering if you could make a bracket/mount on the frame or fender well to perform the same purpose. I'm several months from getting my fenders back on the car to test out the possibilities of this. But thought I'd throw out this thought in case someone wanted to try it out.
JustJohn
07-21-2015, 10:50 AM
I looked at that as well since I just broke and replaced a hood hinge.
Decided it might be easier to just do everything but the hood mount bracket out of billet since I have all the other linkage members to copy. $700 a pair seems pretty steep for hinges.
