View Full Version : bump steer
copo69
09-14-2004, 09:05 AM
:spank2: ok baer has quit making its tracker system for the 67-69 camaro and thanks to a dark street and a raised manhole cover i need a new heim joint type bump steer kit for the 69 camaro rod and all anyone know who makes such a kit ??? thanks
[email protected]
442olds
09-14-2004, 09:42 AM
Check out speedwaymotors.com I think they sell the tie rod to heim adapter like the bear kit and the heim joints to go with it.
dennis68
09-14-2004, 11:28 AM
I have the adapters if you want. They bolt to the spindle and then the rod end attaches to them-with the adjusting nuts. Let me know, we can work out details in PM.
copo69
09-14-2004, 11:44 AM
what do you have exactly i need a complete kit sleeves /well just sleeves will do. is anyone using the speedway kit? if so what tube lengths do you have? 67-69 camaro dennis can you send me a pic please? thanks :icon996:
dennis68
09-14-2004, 03:32 PM
Here is pic of exactly what speedway will send you with the tie rod kit. Mine are 9". The kit runs 39.95 per side and you still need the adapter (which I have :icon996: ). Also is a pic of the adapters, they sell for 11.95/ea.
PM sent.
Marcus SC&C
09-15-2004, 05:31 PM
The Speedway setup is cheap and fundamentally the same thing as the Baer Trackers. I`ve used them before with decent results. But...it sounds like it might be a good time for an upgrade. :) How about modular tall stud tie rod ends? They`ll replace your heims and studs,and give you the altered geometry you want. They`re greasable,O ring/poly sealed against dirt/weather,stronger than stock and rebuildable. The price of $85ea. includes the poly boots. They`re made by Howe Racing. You can order the components and assemble them yourself but we assemble them for you and save you a couple bucks too. You can check them out at www.SCandC.com
copo69
09-16-2004, 10:54 AM
sorry took me so long to get back to you had to go outta town all of a suddon yes i have the speedway kit 17 1/2 length right.. i was hoping you might have the bear kit that got toasted on my car already.. thanks dennis :cheers:
Lowend
09-16-2004, 06:05 PM
What is this about Baer killing the tracker kit?
I just got one for a customer last week
