atomicjoe23
03-16-2015, 08:16 AM
I have a '67 Firebird 400 coupe that I want to start Auto-X'ing (build thread is in the signature block); it's got mono-leafs in the back. . .I know there were mono-leafs and multi-leafs offered for the car. Which of those stock leaf springs are better for Auto-X'ing?
My current priority list is to replace all of the bushings and ball joints on the car including inner/outer tie rod ends. . .those parts are all ordered (Energy Suspension Hypeflex poly bushing and Moog balljoints/tie rod ends). I also have the stock disc brake spindles, rotors, calipers to upgrade from drums in the front. . .I still need to order a new master cylinder, brake booster, and possibly proportioning valve. I'm also thinking of doing the Guldstrand upper control arm mount relocation.
The car currently has a high-rise tunnel ram intake manifold with a stupid Hilborn 3-blade throttle body scoop on it (not my doing or my taste); I am going to get rid of that and go with an Edelbrock intake manifold and a 400 hood.
That is all I want to do to the car right now. . .I want to get it up to snuff and out on the track where I can enjoy it. I will eventually be upgrading things like the upper/lower control arms and rear suspension to coilovers, but for right now I want to be able to drive the car and learn to drive better. . .once I reach a point where my driving skills are up enough that the car is holding me back I will upgrade from there.
So for right now I would like to know if I should swap out my leaf springs for the multi-leafs (or a simularly priced set of leaf springs from another company since I will have to spend money to replace the leaf springs). . .I just don't want to throw a lot of money at parts that are eventually going away.
FYI. . .I had more first Auto-X event yesterday; I got two rides in other peoples cars (a Pontiac Solstice and a Subaru BRZ with the tuner pipe that gets rid of the 40 HP dip in the middle of the power band) and then I got to drive a 400 HP Mitsibishi EVO IX MR with a coach. . .it was a BLAST and I'm HOOKED!!! It was in the rain and it was still a BLAST!!!
Thanks for the help!
