Goosesdad
03-12-2015, 07:35 AM
Project: 70 Camaro PT
Projected use: 70% street, 15% USCA, 10% local Autocross, 5% big track (Portland and Miller Motorsports Park)
I'm at the roll cage stage. My current plan is to closely mimic the roll cage DSE built for Tim McGilton. This can be seen in the Projects section of DSE's website. I'm not sure if it's cool to repost those pics here so I didn't.
http://www.detroitspeed.com/Projects/Tim-McGilton-1970-Camaro/Tim-McGilton-1970-Camaro-pg-1.html
I road with Tim at a Good Guys event and the door bar configuration supported my projected use percentages with mostly easy access combined with a level of safety that seemed to fit with my use of the car. Tim commented that the overall configuration provided significant chassis stiffness. As well, I like the A pillar down bar landing behind the dash instead of in front of it as is common with the cages that are commercially available. I appreciate that with my limited big track activity, a full cage is a stretch but I agree with Mr. Sutton, that if a car sees track time, it should be safe! Thank you Tim, appreciated your time and advice. As well, thanks to Ron for the time you've dedicated to the safety thread! Much appreciated.
Seems with my plan, I'm headed for a complete custom set up here. Alston appears to be able to provide the material bent per my specs so that might be an option. However, I've found a local shop here in Boise that appears to have the skills/tools to accomplish my goals. I've seen their work and the shop and have a high confidence level.
Built per above with 1.75", 0.120 wall DOM, all tig welded. Around $3000 complete.
Appreciate any advice on my design plans and thoughts on the price from my local shop.
Thanks in advance!
John
Thanks in advance!
John
