View Full Version : Edgar Arceneaux's '71 Chevy Nova on Forgeline WC3 Wheels
Forgeline Wheels
03-10-2015, 06:32 PM
Edgar's pro-touring '71 Nova (built by Vince at Meanstreets Performance, in San Carlos, CA) is powered by a 425HP 402ci big block mated to a Magnum Tremec 6 speed trans. It rides on a RideTech bolt-on 4 link suspension, in the rear, with RQ Series coilovers. And the front suspension consists of aftermarket tubular upper & lower control arms, Hotchkis subframe connectors, Hotchkis sway bar, Hotchkis coil springs, RideTech shocks, RideTech Tru Turn steering system, and RideTech 2-inch drop spindles. His brakes consist of Baer Brakes 6P 6 piston calipers and 14 inch rotors at all 4 corners, Hydroboost braking system, Wilwood proportioning valve, and aluminum tandem master cylinder. Custom Mini tubs allowed him to fit some wide BFG Rival tires: 315/35ZR18 in the rear and 275/35ZR18 in the front wrapped around 18x11 and 18x10 Forgeline WC3 wheels finished with Gloss Black centers, Polished outers, and exposed hardware. See more at: http://www.forgeline.com/customer_gallery_view.php?cvk=1313
https://static1.pt-content.com/images/pt/2015/03/ckdd1HM-1.jpg
https://static1.pt-content.com/images/pt/2015/03/5sEFDUz-1.jpg
https://static1.pt-content.com/images/pt/2015/03/Zt0hCLb-1.jpg
https://static1.pt-content.com/images/pt/2015/03/PJUfkFW-1.jpg
rchaskin
03-20-2015, 11:59 AM
Man, Awesome fitment!!!
How about some specs?
F&R backspace, rear end width?
Forgeline Wheels
03-21-2015, 05:12 PM
Edgar says that he is running a 54.75 inch rear end. So his backspacing is 5.5 in the rear and 6.75 in the front.
GS163
03-22-2015, 03:49 AM
That is one nice looking Nova. Love it. My next set of wheels is definitely gonna be a set of Forgelines.
rchaskin
03-22-2015, 05:52 AM
Thanks!!!
03-25-2015, 11:13 AM
Ridetech tru turn and modified steering stops make the fronts possible. No way to do that with a stock set up FYI.
