View Full Version : Trunk pop
Twinstang
03-05-2015, 02:51 PM
Anybody got any pics or ideas how to do a mechanical trunk pop on a 69 Camaro or similar model ? I plan on putting the battery in the trunk so I'm not sure if I want to do a electrical trunk pop yet in case the battery ever dies I also removed the trunk key so that's why I'm nervous about putting some type of electric remote trunk pop on it.
Any my tips would be great ,
thanks John
terrydmorgan
03-05-2015, 03:01 PM
Modo Innovations makes a nice kit that's easy to install. I left my key lock in place, but I suspect it would work without (as long as battery was charged).
https://static1.pt-content.com/images/pt/2015/03/fac4b06567950daec11b15cf979165a5-1.jpg
Twinstang
03-05-2015, 03:49 PM
That is a nice looking kit just afraid if the electric side of it ever failed how would I get in the trunk without having key access
GRNOVA
03-05-2015, 04:09 PM
I have emergency pull behind the tail light lens.
GRNOVA
03-05-2015, 04:12 PM
Behind reverse lens
Twinstang
03-05-2015, 04:13 PM
Behind reverse lens
Any pics how you did it
terrydmorgan
03-05-2015, 04:39 PM
Even with battery in the trunk, you still have to run a hot line to the engine compartment to power headlights, horns, fans etc. You can connect a battery charger/separate battery to the connection under the hood to give you power with the trunk release. I have a Porsche Boxster with the same issue. Porsche suggests connecting the fuse box temporarily to a separate 12V battery to open the trunk/hood. That said, I'd like a mechanical release too.
Twinstang
03-05-2015, 07:44 PM
I could do something like that I guess but I still would like a mechanical release also just incase the electrical side of it ever failed. I will have to figure something out !
GRNOVA
03-05-2015, 09:02 PM
Here it goes
GRNOVA
03-05-2015, 09:03 PM
https://static1.pt-content.com/images/pt/2015/03/A6739C66BDAA486687C40B08C4376DC4_zpsqegt-1.jpg (http://s300.photobucket.com/user/tnt342/media/A6739C66-BDAA-4866-87C4-0B08C4376DC4_zpsqegthwzv.jpg.html)
GRNOVA
03-05-2015, 09:06 PM
https://static1.pt-content.com/images/pt/2015/03/4585ACB8DD2C4735B35E667B5E678993_zpssd11-1.jpg (http://s300.photobucket.com/user/tnt342/media/4585ACB8-DD2C-4735-B35E-667B5E678993_zpssd116afl.jpg.html)
Twinstang
03-06-2015, 04:32 AM
Nice thanks for the pic. Do you have that as a backup to some kind of electric trunk latch ?
sweet motion
03-08-2015, 04:34 PM
I have a 69 Camaro and I did buy the Modo innovations kit-it's perfect and I put an L shaped metal rod where the key rod used to go hooked up to a cable lanyard going through a small hole with a grommet in the trunk floor directly below the latch so if I have no power I reach underneath to pull the lanyard and it opens the trunk
sweet motion
03-08-2015, 04:35 PM
I'm installing the trunk pop button in my glove box-it's a great kit
GRNOVA
03-08-2015, 04:44 PM
Yes I shaved the trunk key hole so I can pop the trunk if the battery goes dead by removing the reverse lense and pulling rip cord. I also installed battery jumpers under the tail light.
https://static1.pt-content.com/images/pt/2015/03/f07b4cd27163bf34a2817c45a5e64490_zps94cc-1.jpg (http://s300.photobucket.com/user/tnt342/media/f07b4cd27163bf34a2817c45a5e64490_zps94ccdf9a.jpg.h tml)
