1BAGTO
03-03-2015, 09:56 AM
I have a custom 1970 Pontiac GTO that was purchased from Barrett-Jackson about 4 years ago. The car has been in storage while my wife and were building a house and I am now getting around to making the car “mine” and fixing the things that I do not like about it.
The car is equipped with a Baer “Serious Street” brake conversion, a 7” CPP power booster, and a Wilwood 1.125” bore master cylinder. The engine is a little low on vacuum (between 10 and 14” hg) at idle. The issue that I am having is the car doesn’t stop very well and I cannot “lock” the brakes up no matter how hard I try. I have bled the brakes, checked for obstruction, etc. The research that I have done leads me to believe that the culprit is the Wilwood master cylinder as 1.125” bore masters are typically sized for manual brake applications.
Can someone please point me in the right direction as to what items I need to correctly fix the stopping issue? I have been looking into replacing the master cylinder with the new Baer remaster cylinder in the 15/16” bore size as this is the size recommended for the “Serious Street” setup (according to the Baer instructions provided in the vehicle’s build documentation). Also, is there a booster that is recommended for this application?
I appreciate the help!
Aaron
Aaron
