View Full Version : low vert f body with injection
Ishmael
03-02-2015, 08:23 PM
I did the search and couldn't find exactly what I'm looking for. I have a 68 Firebird Convertible with a hotchkis x brace and fuel injection with lines coming down and over the front of the tank. The car is also low.
I would love to go with a magnaflow transverse except I'm worried about the fuel lines and the x brace. Should I be worried about the lines?
Otherwise if you have a convertible Camaro or Firebird that sits low what are you using?
thanks
Aussie
03-03-2015, 01:56 AM
I used the Magnaflow transverse muffler system. LS1 with T56, transmission crossmember is lowest point. Very happy with how it fits
Ishmael
03-03-2015, 05:00 AM
Did you run your fuel lines down the front of your tank? Was the rest of the system magnaflow or did you build it? I keep reading the x pipe wont be able to be used because of the x brace. Did you use an H or X?
thanks
Ishmael
03-04-2015, 05:50 AM
I found out from various manufacturers that they have heard that many guys have had no problems with x or H pipe when using the hotchkis brace though they can't recommend its use. Now to find out about the muffler and the fuel lines.
Aussie
03-05-2015, 02:19 AM
Sorry for delay, I have Rock Valley (DSE) tank with lines out the front, no issue.
I have X pipe with a custom spaced factory brace. I had a Hotchkis brace also, cannot remember why we went with spaced factory, maybe something to do with park brake cables
Ishmael
03-05-2015, 06:45 AM
Great,the I never thought about the cables.
thanks
MAGONSTERZ68
08-11-2015, 08:09 PM
In in the same boat! Hope the expert tech support over at HOTCHKIS AND HOLLEY have their thinking caps on for this one as i have yet to get a definate answer.
68 Camaro convertible LS2, Hooker LS swap plates12618HKR,Hooker 4l65 auto trans crossmember 12625HKR and Hooker mid length LS header Part# 2474-1HKR
QUESTION:
Will the X flow section of exhaust kit 3" header back exhaust system pn42504HKR interfere with the hotchkis x brace pn1404, i realize it will require use of hooker adapter pipe kit 42504HKR 3 in?
Ishmael
08-12-2015, 05:00 AM
I found out the 2.5" kit works. The holley crossmember helped other than I had to cut it. I don't know about a 3" as I just didn't need that size. My e-brake cable runs below the x-brace. I posted pics in this forum. There may be a pic on there that would let you know what kind of clearance you have.
MAGONSTERZ68
08-12-2015, 02:40 PM
thanks Scott Hooker designer got back to me and stated that at the time of exhaust design this combination did not exist however i did find out that the hotchkis xbrace will accommodate 3 inch tubing with a straingt "H" set up bent up at a shop. I want mandrel bent system and no one in bakersfield can do at an affordable price for stainless. i may just have to see what return policy is and order up / mock up and see for myself when the time is near seeing how 3" works and just a matter of how xflow will or will not clear conv x brace.
Toddoky
08-12-2015, 06:03 PM
I just realized that your car is a convertible and can save you a bunch of headaches by letting you know now that the Hooker 3" exhaust system is in no way compatible with the convertible X brace.
