View Full Version : IN STOCK! Rick's Stamped Steel 67-69 Camaro / 68-74 Nova EFI Gas Tanks
MCB Matt
03-02-2015, 05:16 PM
Ok guys, here it is! The long awaited Rick's Tanks RESTOMOD Stamped Steel tanks!
The tanks are IN STOCK in Texas, ready to ship.
Current applications available: 67-69 Camaro/Firebird and 68-74 Nova / X-Body
The Vitals:
Clipped corners for Mini Tubbed Cars
16.5 Gallon Capacity
Straps included
Will NOT work with Narrowed LEAF springs
Uses either the 5th Gen Camaro pump, ZL1 or CTS-V
Adapter plate coming soon to use a Walbro or similar single or dual pump setup in place of the 5th Gen style pumps.
No internal baffles, we have all seen they are not needed and are not even used in the Vaporworx tanks anymore..
The Fuel Level Sending unit is available in a few different configurations, either the generic 5 bolt pattern basic units used in the Tanks Inc type systems or the Isspro Tube Style, available with your tank purchase.
All tanks are painted Flat Black
Available "Dynamic Pump Module" Kit. This includes: Gen 5 Camaro pump with modified regulator (necessary), Dual corner pickups, Wiring harness, Pushlock Fitting and Fuel level sending unit. This unit is an easy way to make an easy Bolt-in setup vs purchasing each part separate and modifying the Regulator on the new pump.
The bare tank is under $400 list!
We can package it up with just a pump, sender, DPM module, however you want it... Just give us a call, Email or PM with your Model and Year.
MCB Matt
03-04-2015, 01:45 PM
We have received many inquiries as to what it would cost for a turnkey tank "package" with the Dynamic Pump Module kit.
This pump kit will get you everything you need other than plumbing and wiring it up. The Pump Module kit will Come with: Gen 5 Camaro pump, Modified Regulator, Corner Fuel Pickups, Wiring Harness, Pushlock fitting and Fuel Level Sending Unit!
67-68 Camaro / Firebird $995 shipped (48 states)
69 Camaro / Firebird $1010 shipped (48 states)
68-72 Nova $1029 shipped (48 states)
MCB
MCB Matt
03-05-2015, 10:07 AM
More Details...
cwylie
03-26-2015, 11:42 AM
https://static1.pt-content.com/images/pt/2015/03/IMG_9288-1.jpg
https://static1.pt-content.com/images/pt/2015/03/IMG_9289-1.jpg
https://static1.pt-content.com/images/pt/2015/03/IMG_9291-1.jpg
https://static1.pt-content.com/images/pt/2015/03/IMG_9295-1.jpg
https://static1.pt-content.com/images/pt/2015/03/IMG_9296-1.jpg
MCB Matt
03-26-2015, 01:52 PM
Looks good Chris! Let us know how the install goes and how you like the performance once you get it running!
Thanks again for the business
Matt
