View Full Version : Wheel studs LS1 swap reason
70chevellemalibu
03-01-2015, 06:35 PM
Hey there, I did a search and I know that everyone does the wheel stud swap but why is it done?
I have a 70 Chevelle that had 4 wheel drums and is now LS1 4 wheel discs the studs seem to be long enough with my Budnik Billet rims so i dont think i need new studs....
any thoughts?
bad86ss
03-02-2015, 06:22 PM
There's a slight added width going from drums to slip on rotors. I have stock length studs on the rear of my 86 Monte and ls1 rear disc and theres still enough stud for my comfort
Typhoon1015
03-03-2015, 05:47 AM
It all depends if there is enough threads once the hub/rotor/wheel is mounted. I choose to replace for the sake of replacing with new and went 1/4 inch longer to ensure proper thread engagement when torqued. If you have less threads, you will have more load per thread which could cause premature wear/failure of the thread.
70chevellemalibu
03-03-2015, 10:02 AM
okay thanks.
nokones
03-04-2015, 04:57 PM
I would buy the long studs from Lingenfelter. They're not that expensive and you can't go wrong with the long studs.
