View Full Version : Baer 6p on ride tech drop spindle for 69 camaro
Vegasboxer
03-01-2015, 08:20 AM
It appears the main bracket bolts for the Baer system will interfere with the ride tech front sway bar linkage. Has anyone else run into this? If so did you trim the bolt length as they appear to be several inches longer than necessary?
Nativefx
03-08-2015, 09:13 PM
I originally came across this when installing the same setup on my 69 Firebird. Although once I started the installation of the TruTurn setup, it came with a different set of bolts which went through the opposite direction and had a nut that was tapered on one side. I believe in the instructions, if you are NOT using the TruTurn setup then you will need to trim the longer bolts. That's what i remember so you should read through the directions to verify.
