WallaceMFG
02-26-2015, 05:20 PM
Hey guys,
I found out that because of my brake setup I will not be able to fit the 17" wheels I had planned on the car, so I'm going to have to get some 18" wheels. My main question is on the width and tire size. I've seen several places telling me a 18" x 10" will fit on the back no problem, but will these fit on the fronts? I've been told that an 18" x 9.5" with 20mm offset will fit all four corners with a 245/45r18 up front and 285/35r18 out back, and one of the wheels I've looked at comes in this size. The other one my dad mentioned comes in 18" x 9" or 18" x 10" with 0mm offset. I would like to run the same size wheels on the front and rear so that I can rotate the tires as they wear, and bigger is better.
The car is a 69 Chevelle, full Ridetech stage II coilover system, C6 Vette brakes on front & LS1 Camaro brakes on the rear. The wheel tubs have not been modified yet and we will be running front inner fenders.
So what wheel/tire size should I be looking for? Any suggestions are appreciated, I don't wanna end up with a car that's undriveable, but I don't wanna jack the ride height way up either. Thanks!
