blznnp
02-25-2015, 09:26 AM
I have a 68 camaro with a LS3, t56, stock subframe. right now I have some careera coil overs up front with 450lb spring rate and don't know the name coil overs in the rear with 250lb spring rate. The front suspension is heidts upper arms and spindles. The rear is a TCI torque arm. I love the stance of my car right now. I like the ride, but I am thinking of going with a 500lb up front and a 300-350lb in the rear (not sure if they make a 300) The reason for this, is to try and make the suspension a little more stiff so on decent bumps the tires don't hit the fenders. Right now the coil overs are non-adjustable when it comes to the shocks. I have a upgraded sway bar but can't remember the size for the front. No sway bar in the rear. I want to get the car to the road course but with my kids and limited time, that could be a while before I get into the scene more so right now, its just a street car. But taking it to the track is the ultimate goal. My question is, would going with stiffer springs help or would I be more beneficial to get some adjustable shock coil overs? The weight in the rear is just a bare trunk, I will be adding some trunk panels to clean it up and maybe a subwoofer but most likely not, so there isn't much weight in the back.
