View Full Version : 82 c10 ls swap ly6 6l90
turboassault
02-19-2015, 07:23 PM
Hi guys new here. I have a ly6 6l90 combo that the gas pedal won't work on. It fires up and idles no problem but won't respond to the pedal. It has a stock pedal wired up as a stock truck. It has a corvette tune in it. Do i have to wire the pedal differently because of the corvette tune? Or get a new pedal also? Thanks in advance
Schwartz Performance
02-19-2015, 08:02 PM
It's most likely a connector pin that is pulled out. Or just a faulty pedal. The tune shouldn't affect that.
-Dale
bsharpe
02-21-2015, 12:18 PM
You need to switch the wiring to match the pedal. switch pins d and f on the pedal connector. I just did a LQ9 swap in a 77 stepside but it was a lifted 4x4.
