View Full Version : Kooks headers seem a little low....
Ryanater
02-18-2015, 05:34 PM
I just replaced my previous set of headers with Kooks LS swap headers hoping for more ground clearance. While I did get about 1" of ground over my last set, I still think they hang a little low. I was wondering if maybe I have the wrong motor mount towers or there is something else that I missed. I am using the headers with Dirty Dingo slider mounts just like they recommended. Other than ground clearance, the headers fit great. Maybe I am asking for too much, but it would be really nice if they didn't hang down much lower than the subframe. It looks like there is plenty of room between the headers and the floorboard.
Has anyone else had experience with these headers? Is this how they were designed and I just need to suck it up and raise the car up?
They are on a 69 Camaro with an LS1.
https://www.pro-touring.com/attachment.php?attachmentid=109222&stc=1
https://www.pro-touring.com/attachment.php?attachmentid=109223&stc=1
Ryanater
02-18-2015, 09:58 PM
Just for reference, I believe I am using 69 396/350/302 frame towers and engine mounts. (not 100% sure since it's been a couple years since they were installed)
130fe
02-19-2015, 06:02 AM
This is a good post from over at Lat-g http://lateral-g.net/forums/showthread.php4?t=47612&highlight=motor+mount I would look at the way the motor mounts are bolted up to the block. Hope this helps!
Ryanater
02-19-2015, 08:44 AM
Thanks. The only problem is that I don't believe the Dirty Dingo slider mounts can be flipped. I will try it and see though. Good thinking. Thank you.
dhutton
02-19-2015, 10:24 AM
I think those stands set the engine lower to allow for the four barrel carb. I would try the other ones.
Your oil pan also looks low to me.
Don
Ryanater
02-19-2015, 11:41 AM
Below is a quote from pozziracing.com. From this information, it looks like the tall mounts wouldn't really do much (maybe .25"). The frame stands are taller but the actual engine mounts are shorter. Has anyone had experience with this?
"The total height for a 69 Z/28 and high performance mount and frame bracket is:
LH 3 5/8"
RH 3 3/4"
69 motor mount thickness: 2 1/8". (subtract this from above to get frame bracket height).
The total height for A 67/68/69 low performance frame bracket and motor mount is:
Also 67/68 high perf
LH 3 11/16"
RH 3 15/16"
67-68 V8 all, and 69 low perf motor mount: 1 5/8" thick. (subtract this from above to get frame bracket height)"
Ryanater
02-28-2015, 09:21 AM
Problem is fixed. I found out that I already had the low performance SBC towers installed (that was a lot of work to figure out I already had the right parts...). I ended up making 3/8" shims for the motor mount pads and transmission mount. This helped a lot and everything fits great now. I still think it would be nice if the headers didn't hang any lower than the subframe, but that just isn't going to happen.
FWIW: I tried flipping the dirty dingo slider mounts upside down and it didn't really do anything other that create a lot of work trying to get them in and out upside down.
