Results 1 to 13 of 13
02-13-2015 #1
- Join Date
- Apr 2008
- Posts
- 419
A little help from the Pozzi's with my brake master
I noticed Mary's camaro has the same dual brake master cylinder as the one I got a while back to put in my 2nd gen. I was hoping to pick your brains for some pointers on install and setup of that master. Such as which side did you hook up the front and rear brakes to (although I don't think it matters)? How much did you have to adjust the bias bar (balance bar)? Although I have messed with it back and forth already so I have no idea where it was originally. How did you connect to brake pedal? The clevis that came with the brake pushrod I bought doesn't line up. I was thinking of using a rod end instead. And finally your general thoughts and opinions of the master and anything else you can tell me to help? I really like your cars and you two have had a big impact on my interest in the sport. I will follow up with a pic or two
Mike A
69 Chevelle
496 Big Block
02-13-2015 #2
- Join Date
- Apr 2008
- Posts
- 419
Mike A
69 Chevelle
496 Big Block
02-14-2015 #3
- Join Date
- Mar 2005
- Posts
- 345
Not sure about the other questions, but the larger {edit, was: smaller} diameter M/C is for the rear brakes.
Bob.Last edited by a67; 02-14-2015 at 11:16 AM. Reason: goofed up
02-14-2015 #4
- Join Date
- Sep 2011
- Location
- Southern Ontario
- Posts
- 640
