    Results 1 to 12 of 12
      Jan 2015
      ft myers,fla
      adjustable proportion valves??
      I plan to re do my whole brake system. I am going disc brakes all around. With bigger rotors and at lest dual piston calipers. Do I need to replace my factory proportion valve with a all in one adjustable one or can I just a add a adjustable valve to my rear brake lines?
      Apr 2012
      Woodstock, IL
      Adding an adjustable one to the rear brake lines would be ideal. You don't need one in the front. Just make sure your master cylinder is the proper size
      -Dale
      SchwartzPerformance
      Feb 2013
      Ft Worth, TX
      http://www.summitracing.com/parts/wi...FYREaQodvo0AyQ
      This is one of the best starting points for a new brake system. It combines a proportioning valve, distribution block, and brake light switch if you need it. I run one on my Chevelle.
      1970 Chevelle: 6.0 L96, T56, Strange 9 Inch, Ridetech Coilovers, Wilwood brakes
      1978 Firebird: 6.0 LQ4, T56
      2007 Sierra 2500HD LBZ
      Jan 2015
      ft myers,fla
      Should I use a all in one or just add a adjustable one to the rear brakes
      Feb 2013
      Ft Worth, TX
      Both accomplish the same task. It just depends how you want to run your brake lines. In my opinion, if you're starting from scratch the all in one unit is the simpler and cleaner way to go.
      Jan 2015
      ft myers,fla
      Thanks, I will order the all in one unit
      Oregon
      You haven't specified the application, however you do not want to add a proportioning valve if you already have one in the system, so if the car currently has a proportioning valve of any kind, it should be removed or gutted before you add another one. Two proportioning valves in the same circuit is no bueno. If you do order the distribution block linked to above, Wilwood #260-11179, then I would assume that you're going to be fabricating new hard lines for the car. Is that correct? All of the inlet/outlet ports are 3/8-24 inverted flare, the standard tube nut size for 3/16" hard lines.
      Based on your handle "bbc monte", I can only surmise that you may have something from a 1970 to a 2007 Monte Carlo. Even if we rule out the front-wheel drive applications, there are still several brake plumbing configurations to choose from, but we can be more specific if you provide more information.
      FWIW, I would remove the pressure sensor from the Wilwood 260-11179 distribution block and replace it with an 1/8" NPT plug if you're not going to use it. The electro-mechanical switch on most GM pedal assemblies is a much more reliable means for brake light actuation and doesn't have the hysteresis (pressure differential between turning on and off) associated with that type of pressure sensor.
      Tobin
      KORE3
      It's what I does.
      Jan 2015
      ft myers,fla
      I have a 70'Monte Carlo and I going to run all new brake lines
      Jun 2012
      Order is with the bracket
      Tim
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
      Jan 2015
      ft myers,fla
      Nice, did it come with a bracket
      Jun 2012
      Yes and 1 line I bent the other.
      Tim
      86 Mustang
      Jan 2015
      ft myers,fla
      Thanks, I am going to order that kit
