Offroad Outlaw
02-08-2015, 08:45 PM
Ok... befor i go askin questions let me throw a few things at you... I have ABSOLUTLY no road course or pro-touring experiance....
I do however have an extinsive background in metal fab in all areas and i have built show cars... Rock Crawlers... airbaggers... Hydrolics... and... well over 20+ Dirt track cars ranging from your... advrage knock the windows out of a camaro cut the roof off and put a cage in... to full blown tube chassis 3 wheelin dirt mods... aswell as some preety outragouse 4x4s... so there isnt too many types of suspensions that i havent layed my hands on....
EXCEPT..... truck arms... or better know as rear suspension for the nascar world that came from early 70s chevy trucks... hence the name... this is the subject that i need ANYONE with expieriance with this setup?
The Vehicle...
1993 chevy s10 blazer 2dr
Chassis....
Modified 1974-1982 camaro front clip...2x3 boxed framerails and Truck arms in the rear... o yea....fully gutted interior and caged like a full blown racecar but....for 4people
Modified dimensions...
100in wheelbase... 74in track width... 3300lbs with all 4 seats filled... 2500lbs no people
Body mods....
since the track width is wider... so must the body grow...8 inches to be exact.... so front is easy and will just be some fiberglass 4inch baja style s-10 fenders. Its easy....cheap...looks mean...and lighter... The rear i will be making my own flaired bed sides by usin long bed quater panels.... ill do the metal work since i have a big v8 up front... it will help with overall ballance... i know its going to resemble a baja truck slammed on the ground.... but thats the idea.... cuz baja or short course trucks looks mean as hell lol...
Drive train...
360 cid SBC 600hp@7800 rpm...aluminum heads... water pump and accessories... T56 6spd... 4.11 rear gears with a mini spool locker
Wheels and tires...
18x15 Hoosier Asphault slicks for track and 18x12 for street
The kicker...
STREET LEGAL!!!
My reasons....
(Front)
Well ive always heard important chassis builders and racing people in general say... "in thier opions the 2nd gen camaro is the best front suspension designs as far as steering geometry ever created"... And as i said befor ive spent many years in dirt track racing and have a hude knowledge of the 2nd gen camaro front suspension... so modifications will be including... relocating upper control arm mounts for better caster/camber... tubular upper control arms... chrylser style screw in ball joints and #2 gm spindles with 5x5 hubs...running outboard shocks and installing "screw jack" spring buckets... (i know its not the right name but if you would like to me explain i will)..... but bassically.... a 1978 camaro front sub frame haha... O yea... dont let me forget Speedway magazine... They supply us dirt track boys with any rate spring.. any shock... any lengh tubular control arms... all the bushings....ANYTHING possibly needed..all built to race specs for the camaro... AND CHEAP!!!
(Rear)
There are many reasons i want the truck arms... The main reason is because... well... why not? Ive never messed with it and wanna try it... Nascar has used it for years... there is no heim joints to make rattling noises... and from what ive heard.... could work well for what im building....
I live in a rual community in Bumfooked Arkansas....USA....And will be driving on ALOT of gravel roads.....i know what your thinking.... but i will have ride height adjustment and string rate stiffness at the turn of a 1/2 ratchet.... and could raise or lower all 4 corners of the car a total of 4 inches up or down in under 15 minutes..... so yes it may not be the most comfortable ride... but itll be one heck of a good time haha
Please... im not looking for people to hate on my ideas... i have my reason and have most of my parts.... this isnt some pipe dream but infact is a well thaught out idea... and will be finished in the year or so...
I know i gave way more info than needed but im hoping sombody has the knowledge im looking for.... mainly... truck arm rear suspension... i know from messing with 3 and 4 links... that lengh matters.... and there are alot of factors that go into me choosing a set of links for a specific setup... sooo how do i figure out my best lengh for a truck arm? Whats the best spring placement? Were should i hang shocks? Anything i should be away pf as far as the downside to truck arms? .... any experiance would help a ton
THANKS'
The Vehicle...
Chassis....
Body mods....
Drive train...
Wheels and tires...
The kicker...
STREET LEGAL!!!
My reasons....
(Front)
(Rear)
THANKS'
