View Full Version : seam sealer points
MARBIL
02-08-2015, 08:20 PM
I just finished blasting and priming the underside of my 69 firebird, my problem is I stripped the car a long time ago (years) and cant remember every point where the seam sealer was applied, is there a diagram somewhere that shows points of application? or if anyone knows that help would be great.
Thanks Bill
no go nova
02-09-2015, 01:29 AM
Just seam seal any spot the water can get in.
MARBIL
02-09-2015, 08:19 AM
I don't remember the rear frame rails sealed, or the fuel tank mounts.
redss86
02-12-2015, 10:51 AM
Depends on if you are going with an "Original" restoration of not. If original, I can't help you there. If you are not worried about being factory original then I would deal every sheet metal joint on the underside. Anywhere moisture can get between two labels is potential problem. Same thing goes for the inside.
