View Full Version : Saw this explanation of the old TPI system on another forum and found it informative
vintageracer
02-08-2015, 04:13 PM
From Fullsizechevy.com. A post about the old TPI system I find interesting!
This response was to a post where the OP wanted to use a late model 880 truck block, remove the Vortec heads, use TPI heads, TPI Injection with a boosted power adder. Many responses as to why this was not a good idea. There were also discussions about the differences in SFI, Multi-port, TBI ect.
This particular response appeared to me to be a great explanation about why the old TPI was so limited compared to today's technology but was considered then the "Cutting Edge" technology behind TPI.
I hope you enjoy this explanation as much as I did.
As is anything on the internet it could all be BS but it sure sounds good!!!
"TPI doesn't particularly generate "low RPM" torque. Common misconception. TPI generates "3600 RPM torque".
The way it works is, it uses the compression-rarefaction pulses, aka SOUND, created in the runners by the air rushing down them at high speed and slamming into the back of the intake valve as it closes.
The speed of sound is about 1100 feet per second, + - the effect of temperature and pressure; just to keep the numbers round and handy, let's call it 1000 feet per second. That means sound travels 1 foot in one millisecond. Keep that constant firmly in your mind as we go on.
Imagine what's going on in the runner during an intake event... the valve is open, the pressure in the cyl is lower than atmospheric because the piston has been going down, and the atmosphere is pushing air down the runner. This tall column of air is now rushing down the runner toward the cyl. It's heavy, and has inertia; i.e. once it's moving, it wants to STAY moving. Presently the intake valve closes. The air is still moving, trying to rush on down there; it smashes into the back of the freshly closed valve, and bounces off, creating a pulse of SOUND having positive pressure. This pulse travels back UP the runner at the speed of SOUND (remember the 1 foot per millisecond #) and reaches the plenum. It bounces around in there a bit, and some of it finds its way into THE NEXT runner in the firing order, which is now experiencing ITS intake event. This pulse from thes PRIOR event ADDS to the pressure in the runner of this NEXT event, packing the cyl a little bit more full than the atmosphere alone. The process repeats itself at each firing; each cyl's intake fill event is reinforced by the pulse left over from the PRIOR cyl's intake valve closing event.
OK now that you understand HOW IT WORKS, here's the numbers. The sum total of the length of the intake tract from the plenum to the valve is about 22"... just shy of 2 feet. So, the SOUND wave travels UP the runner at 1 foot per msec, passes a few inches through the plenum, and down the NEXT runner at 1 foot per msec, to reach the cyl. This means the sound wave takes 4 msec to get from one cyl to the next one in the firing order, right? So when the time between cyl firings is 4 msec, the "tuned" aspect of "TPI" is in effect, right? All you gotta do to now is figure out what RPM corresponds to 4 msec between cyl firings and you know what THE ONLY RPM that TPI reinforces is.
Well, 4 msec is 1/250 of a sec, meaning this is when there are 250 firings per sec. Again, permit me to round off, just to keep the numbers easy; call it 240 which is plenty close enough. Since 4 cyls fire per crank revolution, then that means this occurs when there are 240/4 crank revolutions per sec, which is 60. 60 revs/sec = 3600 RPM.
Eh??
So you look at a dyno run for a TPI motor, and you will see this "Mount Everest" looking feature on the torque curve, of this GIANT peak of torque at 3600 RPM.
Sounds great in principle.
But there are 2 problems. The first is, in order to get the pulse that makes TPI work to occur AT ALL, the intake valve has to close VERY early in the cycle. Cams that close VERY early are by definition VERY small. THis means, in order to get TPI to work AT ALL, you MUST use a cam that has NO UPPER RPM CAPABILITY WHATSOEVER, which is where "low RPM torque" comes from. It's not that TPI as such makes "low RPM torque", it's that it FORCES the cam to only be capable of "low RPM torque". The second is, there's a negative pulse of sound right behind that positive one (sound being what it is), and that NEGATIVE pulse has THE EXACT OPPOSITE effect on cyl fill if it reaches a filling cyl. Well it works out that exactly that occurs; at 5400 RPM, WHATEVER benefit you got fro the "T" effect at 3600 RPM, you get AN EQUAL AND OPPOSITE effect (destructive resonance) at 5400 RPM. TPI's torque curve therefore, instead of looking like a gentle rising curve up toward some RPM and then a gentle slope off, looks like a relatively flat line until 3000 RPM or so, then steeply rising to a peak at 3600 RPM, then STEEEEEEPLY falling off from there. The HP curve, instead of rising at a 45° angle to the peak HP RPM (because HP is the product of torque x RPM x a constant), looks like a 45° curve up to 3000 RPM, a steeper rise to 3600 RPM, then a flat line, then it craters at around 4800 RPM. Since HP is torque x RPM x a constant, then if torque falls off as RPM increases, then HP never builds up either.
It's WEAK. No matter what you do, those long runners force it to be WEAK. The only way around it is with boost. Since of course with boost, all of the atmospheric pressure related behaviors are overwhelmed by the artificially raised pressure in the intake tract.
THAT'S why you don't want TPI. Has nothing to do with whether it's SFI or not. At the time it was introduced, it was "state of the art", when compared to 70s smogger motors; now, it's hopelessly obsolete and underperforming compared to what has come after. It's why, for example, a ZZ4 is "rated" at 345 HP gross with a carb (probably 275 or 280 net HP), but the IDENTICAL SAME LONG BLOCK except with a weeenier cam is "rated" at 230 net HP when it has TPI on top."
MonzaRacer
02-08-2015, 04:34 PM
First of all, most people read and listen too all this "information" then aftermarket makers buy in and develop different runners sizes, upper and lower manifolds, etc.
I have watched old school TPI both stock and modified in form make some VERY impressive power numbers both NA and boosted.
Change just one factor in its design, and you change its torque range/output.
NEVER make blanket statements about any part. I had a guy bash my Edelbrock Scorpion intake, then was told it would never work for my previous 355 that was in my yellow Monza, and then he had to get 12 stitches in his bottom lip after reaching for $100 on the dash AND not understanding just how hard it ran or launched.
He later bought the same engine and found out it didnt work as well with a Performer RPM but was still much stouter than anything else he could buy for same price.
He STILL wants that intake.
I am gonna use it on my 283 till I get some sort of controller lined up and wired for the LT1 intake I have.
1989GTA
02-08-2015, 04:58 PM
Just for general information I have been slowly modifying the TPI system in my 1989 Trans Am over the years. The best I have done at the track is 11.57 @ 116 mph. This is on a fully loaded GTA model. On a Dyno Jet it puts down 415rwhp at 6200 rpm and carries well past 6500 rpm. Plenty of power through out the RPM range.
jlcustomz
02-10-2015, 02:13 PM
Magazine articles many times print just enough bs to be confusing, not helpful. When ls engines were first out in the market, properly modified tpi engines were well ahead of them in total power output. Probably much worse than the tpi intake design as compared to todays stuff was the non sequential obd 1 computer system & the quality of the older wiring connectors & relays .
While true that a stock tpi system would choke the upper rpm of particularly a larger modified engine, making 500 ft lbs of torque on a built street 383 wasn't too shabby for moving a heavy vehicle.
H2Ogbodies
02-10-2015, 06:33 PM
Well, I'd say GM definitely designed the LS motors with an eye on performance and the later 6.0 and 6.2 heads are massive in runner size compared to a TPI setup. Now, if you even up things a bit with a nice set of AFR's, a StealthRam intake up top, a grumpy but not overly aggressive roller cam, etc. etc. you can easily (with a tune) get to the 500-600 HP mark with a N/A TPI setup.
Let's not forget too that the TPI system took a backseat to the LT1 engines prior to the LS-and they too get a bad rep. So will the LS motors when GM decides to shake things up again.
andrewb70
02-10-2015, 08:24 PM
Who even cares about TPI anymore? LOL
jlcustomz
02-11-2015, 04:19 PM
Eh , people who still own one.
People who bought my old schtuff years ago.
People like 89 GTA who built a cool as hell manifold or 2 themselves.
vintageracer
02-11-2015, 05:32 PM
I disagree.
I believe the LS series of engines will be iconic on the level of the original 1955 small block Chevy engine (265) and the 1965 Mark 4 Big block engines.
Each was revolutionary in its own time and became iconic as the General developed each of these engines as the model years progressed. This is exactly what has happened with the LS engine.
We will be Talking about and Building LS engines for YEARS!
andrewb70
02-11-2015, 08:32 PM
I disagree.
Mike,
You're exactly right. The old Gen II LT1 never caught on because it was a transitional design and because it never went into production in trucks, which is where the volume is. The GenIII, GenIV and now GenV engines all made it into the truck platforms which assures us plenty of junk yard engines for decades.
MonzaRacer
02-11-2015, 11:40 PM
Ok so let's get some facts straight. GM brought in some performance ( namely Yates)engine designers to help develop an engine that eventually would actually become production. So called "clean sheet" yet had to maintain specifics of push rod, ohv, good flow/power and longevity. And tata the LSx was born.
As for me I have yet to see GenIII progressing to IV or V as those designations are BBC. I see them as GenIII.2, GenIII.3 etc. As the do share lots of design elements.
W.hat I get kick out of is that there hasn't been more push on Ford/Windsor camp swapping on LSx heads. As they do share bolt patterns.
MonzaRacer
02-12-2015, 12:17 AM
Andrew, much too manys dismay not everyone has $1000-$2000 to do the swap to an LSx based engine. And are very happy with standard 23/18 deg SBC parts that are plentiful.
Considering my buddy built a 3 5/8 stroke 18 deg engine way back when it cost $30k-$50k and now the same engine would go for less than $10k with so ilar heads in an 80-90% CNC port. When his was done the heads came in bare with barely a hole for cutter enter a port. His head porter uses Brodix castings but the only have the name on the outside.
Car runs hard and he was NHRA div 3 champ in 2011 I believe it was.
For my Monza your talking nearly $1000 for just headers, custom accessory mounts for what I am gonna build. And then I have to change trans, buy a controller ,and then you have any where from $5k up in just a junkyard engine and pieces to make it run.
Right now A set of $500 headers, Bob Gumms new motor mounts or motor plate. Any GM trans from pg to 4L to 6L autos and a host of manuals at thousands less.
Me I am gonna have a 54 yr old engine with 50 wish yr old heads and what 20 yr old LT1 tpi intake and with my plan of cheap eBay turbos and some smart planning I intend to make over 600 HP , stock steel crank, Eagle I beams, double humps, cheap flat tappet cam, no $3k fi setup either. For my use a Megasquirt Microsquirt or nodded GM computer (obd1) will do what ever I want.
I don't have big buck job or pile of credit cards. I f my long block has $1000-$1500 in it that will be a push.
Guy down road decided to pull overheating 400 sbc out of show car, replace with cheap aluminum head GM crate motor and threw the crap block, scrounged local racers max bore aftermarket block, had it honed 0.010 over (past max overbore maker says is safe) and swapped in his rotating assembly. He got slightly bigger turbos that I am gonna use, some extrude honed aluminum heads off eBay and its making over 800hp in an old rail he got for hauling it away. He is even still using the old Olds race prepped rear end till gears/axles fail.
Yes, yes yes, LS has better heads factory BUT not everyone wants or can afford to buy/build LSx swaps.
Kind of like me putting the motorhome BBC in my Caprice. Swap can, $900 set of aluminum heads from eBay and I can have solid engine till it needs freshened. And then it will probably only need new pistons and swap in some ARP fasteners.
My buddy has takeout can I could use, and with bigger valves my old 290 heads would run fine and I have a port matched intake, even if it is dead weight cast iron unit. And I do have a Victor Jr that could be repaired and used.
My 454 was $500, proper headers to fit chassis, $150 from eBay, tune up parts as it was air cleaner to oil pan (well gotta swap out truck pan) its pretty much a drop in.
Could even keep stock manifolds it has on it. But I also still have oil cooler and its probably steel crank/7/16 rod engine as it was truck engine.
Play cards right and I can swap in BBC for LESS than $1000 total. And have dependable torque monster.
I have seen more LSx pushed to destruction by actions I have done too unknown age/ condition cars I have picked up.
Just as I said, change one part on old TPI and its tuning design is moot, its gonna be different.
So I am gonna stick too dare to be different, run what I bring and hope I bring enough.
And if it breaks in the immortal words of Bret Voekel " If it breaks , fix it!"
andrewb70
02-12-2015, 08:00 AM
GM refers to the small blocks with the "Gen" designation, last time I looked big blocks used the "Mark" designation. Ford guys don't want to touch anything resembling a Bowtie with a ten foot pole.
