View Full Version : LS3 Supercharged Motor For Sale or Trade
Jdseeling
02-03-2015, 04:33 PM
Up for sale is my Supercharged LS3.This motor came with my 68 Camaro that I purchased last year.I purchased the car from a long time forum member and have a good amount of documentation on this motor.The previous owner of my car was in the process of replacing the big block in the Camaro with this LS3 motor.The motor never ran in my car and was only bolted in the car to transport it when I bought it.It is currently sitting on an engine stand in my garage.
The motor was purchased as a slightly used motor from RPM Motors Inc. in California some time in 2011.What I have confirmed from the owner of Rpm Motors Inc. was this motor was intentionally built for one of his customers C6 Corvette.The motor was broken in on their engine dyno and installed in the Corvette and only tuned on the chassis dyno.I have a video of the motor on the chassis dyno and a dyno sheet showing HP at 800.5 and TQ at 781.6.This was at a high boost run.RPM Inc. told me there was between 500-700 miles on the motor.The motor was then taken out of the car for a combination of it being too much power and the original owner couldn’t finish paying for it.This is when the previous owner of my car bought the motor and had it shipped.
I have gone back and forth with keeping this motor.In the end the HP even at low boost is more than I want and I want a NA motor.This is really the only reason why I am selling and do not need to sell it.
The engine details and a breakdown of what the original cost was for RPM Inc. to build this motor.It was broken down to show the cost for the long block and the supercharger.
Price Quote - RPM Motors Inc. Page 1 of 1
377 Cubic Inch -blower motor assembly with LS3 Heads $10,669.34
Parts Include Professional Machining & Labor Includes
• Wiseco Forged Pistons, coated - (includes wrist pins) • Torque Plate Honed - Plateau Finished
• Akerly & Childs Rings -steel top, Napier LT oil • Line Honed
• LS3 - Block - stabilized • Decked - Perpendicular & Parallel
• LS3 - 3.622 Stroke Crankshaft • Digitally Balanced - tolerance within 1 gram
• Forged Steel - 4340 - 6.125 Long Steel Connecting Rods
• Serdi Valve Job
• King "Race Series" Bearings
• Pocket Blended Bowls
• Dura Bond Cam Bearings
• Professionally Assembled Complete Engine
• Cryo Stabilized Main Caps
QTY Labor Itemization
Price
BLUEPRINT OPERATIONS - Short block each
• Cryo Caps $275 each
• Torque Plate Hone - Plateau Finished $398
each
• Decked - Perpendicular & Parallel $198 each
• Line Hone $198 each
• Digitally Balanced - tolerance within 1 gram $250 each
• Prep All Surfaces & debur $95 each
• Assemble Engine Complete $975
Subtotal for block labor =======> $2,389
Cylinder Head - Induction Operations - Each
• Heads , hand blend, blend chambers-flow match $350 each
• Serdi Valve Job $250
each
• Mill Heads & CC $125
each
• Port TB $100each
• Assemble Heads $95
Subtotal for Cylinder Head Components =======> $920.00
LS3 Head Components
2 LS3 Bare Castings $228.54x2= $457.08
8 Stainless Steel Intake Valves (2.070 Diameter) 10.29 $82.32
8 SS Exhaust Valves ( 1.590 Diameter) 9.27 $74.16
1 Patriot Gold Spring Kit $335.29
Subtotal for Cylinder Head Components =======> $948.85
Block Components
1 LS3 Block $1195.84
1 LS3 Steel 3.622 Stroke Crankshaft $389.51
1 4340 Forged Steel Connecting Rods 6.125 Long $423.57
1 ARP Main Stud Kit $190.23
1 ARP Head Stud Kit $298.61
1 King Race Bearings - Mains, Rods, Cam $287.56
1 Wiseco Pistons (coated) $758.42
1 Akerly & Childs Ring Set $184.57
1 90 MM TB (Late Model- Hitachi Motor) $226.38
8 88 lb. hr. injectors 72.57 $580.56
1 Front Cover, seal, bolts (late model- LS3) $132.58
1 Rear Cover, seal,bolts (late model - LS3) $125.37
1 Valley Cover, gasket, bolts (late model - LS7) $105.11
1 LS3 Wet Sump Oil Pan with Pick-up $358.18
1 Melling - LS3 Oil Pump $297.58
1 Comp Cams Custom Camshaft (blower) $412.56
4 GM Lifter Baskets 8.22 $32.88
8 LS7 Roller Lifters 22.34 $178.72
16 .120 Wall Pushrods 8.35 $133.6
1 LS3 Water Pump $129.66
Subtotal for block components =======> $6,436.49
Subtotal for Cylinder head labor =======>$920.00
Subtotal for Block Components =======>$6,441.49
Total Parts Content $3,309.00
Total Labor Content $7,390.34
Long Block Motor TOTAL =======> $10,669.34
Super Charger Package:
Magnuson TVS2300- $7500.00
Port Blower Intake Manifold-$350.00
8 Rib Blower Kit, Innovators West-$1,568.24
Cog Drive Kit, Magnuson Upgrade-$369.24
Total:$9,787.48
Motor Long Block-$10,669.34
Supercharger Kit w/Upgrades-$9,787.48
Total Package-$20,456.82
This price doesn’t count the Katech matching valve covers, Katech coil relo kit, the 102mm Nick Williams throttle body and new coils and plus wires.These additional items easily exceed another $1500 for a total cost as it sits to be around $22,000.
RPM Inc. does have three tunes on file that they can load for a cost onto a Corvette ECU.I believe they have 10, 12 and 17 pound tunes.An ECU doesn’t come with the motor.I want to point out that at some point during the removal or install of the motor before I purchased a small gash was made on the crank pulley.I will include a picture and I have confirmed with Innovator West that it is not an issue.
I have spoken with a number of well-known engine builders and several industry experts about what this motor would be worth.I got some low numbers and some that were pretty high.In the end it is only worth what someone is willing to spend.I am asking $14,500.00, but flexible.Keep in mind I will not give this motor away. I will not even respond to low ballers or opinions about the motor.If you have something negative to say please be respectful and keep it to yourself.I know everyone is an expert or at least they think they are.If I do not get close to what I want then I will keep the motor.
I do not want to separate the motor any parts that are on the motor come with it.I have all of the supercharger parts to include the intercooler, lines, pump and so on.I will consider traders for complete motors or possibly short/long blocks.I will consider mild or stroked LS3’s and LSX/ LS7’s.This is going into a street car so; drag motors, solid roller cams and so on I do not want.
I am located in Warrenton, Virginia a suburb of Northern Virginia about 40 miles southwest of Washington DC.I will ship the motor but the buyer needs to make all of the arrangements and it will be at the buyers cost.I will build a crate at my cost and get it ready to be shipped.The motor will need to be picked up at my house which I am flexible on timing but you will need a lift gate.If I get my asking price I would be willing to possibly travel within a reasonable distance.That distance will be figured out if an offer is made.I will accept cash or PayPal only.If PayPal is choose then all PayPal fees will be paid by the buyer and added to the price.I will not hold the motor for anyone and the first person to send the money gets the opportunity to buy the motor.
I will answer any question that anyone has and can be reached on my cell phone at 703-447-2058 or email at [email protected] ([email protected]).Sending me a message via phone or email will allow me to respond quicker.
https://www.pro-touring.com/attachment.php?attachmentid=108530&stc=1https://www.pro-touring.com/attachment.php?attachmentid=108536&stc=1https://www.pro-touring.com/attachment.php?attachmentid=108535&stc=1https://www.pro-touring.com/attachment.php?attachmentid=108534&stc=1https://www.pro-touring.com/attachment.php?attachmentid=108533&stc=1https://www.pro-touring.com/attachment.php?attachmentid=108532&stc=1https://www.pro-touring.com/attachment.php?attachmentid=108531&stc=1
FasstChevys
02-03-2015, 06:16 PM
Do you have any interest in selling the short block?
Jdseeling
02-03-2015, 09:35 PM
No, I do not want to separate the motor. Thanks
kirt70camaro
02-04-2015, 06:36 AM
If I hit the lotto tonight it will be mine. Awesome engine good luck selling it.
digs131
04-29-2015, 04:39 PM
Still available?
Jdseeling
04-29-2015, 04:49 PM
Motor is pretty much sold.....sorry haven't updated the status. It is being shipped this Friday.
1nastyZ06
04-29-2015, 06:19 PM
Damnit.....how did I not see this originally a couple months ago??? I had/have the perfect engine for you. Exactly what you were looking for and all brand new with all top of the line internals, etc. and I would have made a deal work with you. Well stuff happens. Hope you are happy with your new setup. It's really hard to beat a nicely built LS3 stroker NA engine. I see it 90% of the time where guys go out and spend a ton of money chasing big HP numbers with power adders such as turbo setup or supercharger. And within a month or less of finishing it and driving it or before they even put one mile on it they are selling it and losing their butt to go with a nice nasty NA stroker setup. Good luck and you will have tons of fun and be very happy with your new setup.
Jdseeling
04-30-2015, 06:06 AM
The motor came with my car. Before I found this car my intention was to build an NA LS motor in a car setup just like mine. I have had high horsepower street cars before chasing bid numbers and didn't want to build a Pro-Touring car that way......or at least yet. HAHA.
Jdseeling
05-02-2015, 02:24 PM
Sold
pro-tour-69
05-25-2015, 06:30 PM
Still have the LS for sale?
