brgarris
02-01-2015, 05:07 PM
About to pull my 3rd member due to a pinion seal leak. Figured while I had it out I may put a different gear ratio in. Currently I have an LS3 525HP with 3.50 gear ratio. The transmission is a T56 magnum with the following ratios: 2.66 1.78 1.30 1.0 .80 .63.
Would anyone recommend a different rear gear ratio? I was thinking about going with a 3.70, but didnt know how much of a difference it would make. Send some recommendations if you have a similar setup!!!
