View Full Version : 12 bolt Eaton issue
PaulF
01-30-2015, 04:39 PM
Installing new Moser axles and while rotating the diff to put the pin back in and finish, the curved washer that spaces one the internal gears falls out. What's the easiest way to get it back in? Do I need to disassemble the springs to gain access to put the washer back in? Thanks.
bryant
01-30-2015, 04:53 PM
put some grease on the thrust washer to keep it in. you should be able to slip it back into where it belongs with out taking the posi apart. using some pick tools throught the small window may be necessary to manipulate it into place,
PaulF
01-30-2015, 08:16 PM
Got it. The grease tip worked great! Thank you.
