View Full Version : AAW Classic Update VSS wiring - What to do with Purple/White power wire??
analyte
01-27-2015, 08:28 PM
I'm installing my AAW CU kit in my Chevelle, and everything has been going well. That said, I'm totally confused as to what to do with the purple/white VSS power wire that's part of the engine kit.
On the schematic, it shows the purple/white going to the same fuse block location as the pink 12V ignition wire. In the written instructions, the wire isn't even mentioned. I'll be using a T56 that has a two wire hookup I believe so only a signal and ground are required.
What does everyone do with this wire, or do you not use it at all? The wires came with terminals already attached so I don't believe I'm supposed to cut/crimp them together to share the same fuse block port.
Thanks in advance!!
Kerry
Spork82
01-27-2015, 08:59 PM
That purple wire will go from the fuse box to the switch on your t56 and then to the solenoid.
I wired mine to a pressure switch on the clutch line. Bypassed the switch on the transmission.
analyte
01-27-2015, 09:08 PM
Where? I only have a VSS plug and the reverse lockout. Sorry, I'm sure I'm over complicating this.....
Purple - ground
Yellow - signal
Purple/white line - VSS power
Purple/Yellow go to tranny or ecm for speed. Correct?
Spork82
01-27-2015, 10:19 PM
I'm not sure about a t56, but on my t5 there is only 2 plugs on the transmission.
There are many members here with that transmission and that harness. I don't want to give you inncorrect info.
dhutton
01-28-2015, 04:35 AM
It has been awhile but I remember there are several options on how to wire this and they are described in the documentation.
Don
